Injector Diagnosis
Old Jan 4, 2014 | 06:05 PM
Rxracer27's Avatar
Rxracer27
Originally Posted by Tugly
Are you getting that off the overhead?
Nope I watch the overhead but do my actual calculations when I fill up. I've noticed my overhead is usually around .2mpg off.
Rob
Old Jan 4, 2014 | 08:09 PM
bunklash's Avatar
bunklash
Subscribing. Mine started about a year ago, but only smoked white on first start after sitting a few days. Now it smokes every morning first start regardless of outside temp, and it has next to no power until the smoke starts to clear. My engine has 128K on it and is definitely not loosing any coolant, oil, or tranny fluid. Are y'all saying it could be GP's or leaking injector? Anything else I can check before going after the injectors?
(Don't mean to hijack the thread, but it fits my problem and a search didn't help).
Thanks, as always!
PS, my mileages is very similar to yours, RxRacer.
Old Jan 5, 2014 | 04:59 PM
Rxracer27's Avatar
Rxracer27
OK just read through the receipts I received with the truck. They did not replace the glow plugs as we were informed. The GP relay was replaced along with under valve cover harness and another harness.
I did a check and it appears I have a single glow plug out on the passenger side.
I will get it replaced and report back the changes.
Rob
1993idi
Apr 7, 2015 10:26 AM
MONAVIERONJON
Nov 18, 2014 09:38 PM
savage250
Oct 15, 2011 03:00 PM
masterc16
Dec 7, 2006 06:01 AM
sean23johnson
Jun 15, 2005 11:03 PM
