4wd not working
Old Dec 21, 2012 | 06:47 AM
sflem849's Avatar
sflem849
4wd not working
My 4wdtruck will not work. The tcase appears to engage bc i can hear it click and the front drive shaft is spinning. I dont see the knuckles that go out to the axle spinning. The hubs are Warns and are locked.
Sorry for the phone typing i will fix it when i get inside
Old Dec 21, 2012 | 06:51 AM
powerstroker100's Avatar
powerstroker100
Okay, first lets see if your transfer case is working
Is it manual?
or the electronic solenoid version?
either way UNLOCK the warns then shift the transfer case into 4hi or 4lo crawl underneath and try to spin the drive shaft, if the truck is in park just like your rear shaft you should not be able to spin either shaft.
hop in the cab and put back into 2hi maybe roll the truck backwards or forwards a bit, hop back underneath and you should be able to spin the front driveshaft
EDIT: Also in 2hi, lift the nose of the truck so both tires are off the ground, LOCK both warn hubs and spin a tire and see if the driveshaft turns, it should if it doesnt you have some type of internal problem, I would actually do this first
Old Dec 21, 2012 | 07:04 AM
jeffreyt's Avatar
jeffreyt
To add a little to what Powerstroke said: while in 2wd, Hubs unlocked, the axle should spin when you grab the u joint and turn it.
Keep the hubs unlocked and put it in 4hi. Try to spin the axle again. If it locks and won't spin, the issue is in the hubs not the tcase or the axle. If it still spins, the problem is somewhere else, and then revert to what Powerstroke said. I'd rule out the hubs before pulling out the jack stands.
Old Dec 21, 2012 | 09:28 AM
sflem849's Avatar
sflem849
Ended up my RF Warn hub cqme apart. The snap ring came off the back.
This snow is BAD. Even if for wheel it barely pushes snow!
Old Dec 21, 2012 | 01:36 PM
powerstroker100
atleast you found out the problem, a lot easier to fix that than to rebuild the dana axle lol
Take your time and stay safe, storm is supposed to hit us tonight I'm excited haha
Old Jan 4, 2014 | 06:47 PM
Mike F250's Avatar
Mike F250
I know, old thread. But, I wanted to add to this because it fixed my problem. Lost 4wd. I have Warn Hubs BTW. I twisted the front drive shaft and found the passenger side axle turned. Locked that hub. Twist again and the driver side axle turned. Locked that and the axle still turned. Pulled the hub apart and found the back side of the hub threw the snap ring. Replaced it and all is well. I have 4wd again. The workings seem a bit loose compared to the passenger side. So, maybe a worn warn... We'll see.
Old Jan 5, 2014 | 02:02 PM
grec-o-face's Avatar
grec-o-face
Yesterday I found myself with intermittent 4x4. This is what I found...
Old Jan 5, 2014 | 02:55 PM
jetdoc's Avatar
jetdoc
That's a lot of money for a hub that isn't very reliable....
Old Jan 5, 2014 | 03:13 PM
grec-o-face
I agree.
I've had these hubs in two trucks, for a combined 4 years.
Old Jan 5, 2014 | 04:13 PM
Bonanza35's Avatar
Bonanza35
There not life time guarantee? I thought the good one's were.
Old Jan 5, 2014 | 04:35 PM
grec-o-face
I can't remember. I'm going to do some homework and find out.
EDIT:
http://www.warn.com/truck/hubs/premium_hubs.shtml
"Lifetime limited warranty"
Old Jan 5, 2014 | 05:07 PM
Bonanza35's Avatar
Bonanza35
Boy, we pay the price but the proof is always on us. You can call and maybe have them to send the parts needed. They are there best one's and there mitt of been a problem with them. I bet you don't have the receipt right? I wouldn't after that long either.
Old Jan 5, 2014 | 06:30 PM
HKusp's Avatar
HKusp
I had Warn premiums and they are junk. The spring is weak. I went with Superwinch. There is no spring. It is a mechanical wedge. It can't fail like the Warns, and they are cheaper. Check Amazon.
mesnipe
Jan 10, 2015 11:40 AM
drburnerllc
Sep 10, 2012 03:31 AM
dirtynorth49
Aug 20, 2011 07:00 AM
Pat_D
Dec 11, 2008 06:05 PM
865.0F150
Oct 27, 2006 09:37 PM
