please help
Old Jan 2, 2014 | 09:16 PM
Money-Pit's Avatar
Money-Pit
Originally Posted by baller9409
not sure. i had the heads done again about a month ago and its been doing this ever since
I somehow missed this the first time around....what exactly was done to the heads? Sounds like something got messed up when the heads were done. (again) What problems have you had with the heads?
Old Jan 2, 2014 | 09:46 PM
baller9409's Avatar
baller9409
which harness?
Old Jan 2, 2014 | 09:50 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
which harness?
Engine harness, it sits on the engine topside. They typically remove it when they do studs.
Old Jan 2, 2014 | 10:10 PM
baller9409's Avatar
baller9409
my headgaskets went again. on a studded motor...
Old Jan 2, 2014 | 10:24 PM
9228.bobcat's Avatar
9228.bobcat
What kind of headgaskets did you use?? Did they check the heads for cracks and flatness?
Old Jan 2, 2014 | 10:59 PM
baller9409's Avatar
baller9409
oem gasket both times. heads machined both times.
Old Jan 2, 2014 | 11:11 PM
9228.bobcat
Dang. Machined both times! I believe .008 is the most you can shave off.
Old Jan 3, 2014 | 12:22 AM
baller9409's Avatar
baller9409
yea. im pretty sure im at the limit, i have a year warranty on the work so hopefully if it blows again, its within a year
WatsonR
May 25, 2018 04:31 PM
96powerstroke
May 15, 2013 06:12 PM
Kyle_KleinSS
Feb 21, 2011 05:15 PM
aocabrown
Dec 28, 2007 11:08 PM
toddnga2002
Mar 29, 2003 04:25 PM
