please help
Old Jan 2, 2014 | 07:14 PM
baller9409's Avatar
baller9409
please help
my trucks been doing this **** for almost a month and my mechanic cant seem to figure out what it is. my ficm was dropping to 35volts so i replaced that but its still doing this
Old Jan 2, 2014 | 07:18 PM
9228.bobcat's Avatar
9228.bobcat
Guess I dont know what its doing according to your video. I finally heard what you mean. Your oil isnt over filled is it? Could be bad icp sensor
Old Jan 2, 2014 | 07:24 PM
baller9409's Avatar
baller9409
not sure. i had the heads done again about a month ago and its been doing this ever since
Old Jan 2, 2014 | 07:33 PM
9228.bobcat
Try unplugging the icp and see if that helps.
Old Jan 2, 2014 | 07:35 PM
9228.bobcat
What year of truck? Any codes?
Old Jan 2, 2014 | 07:37 PM
Rusty Axlerod's Avatar
Rusty Axlerod
ICP/IPR is going to fluctuate a little with rpm swinging like that, but verify IPR duty cycle isn't high.
I would look at fuel pressure first. (a guess I admit)
New fuel filters- properly installed.
Factor oil filter cap and filter.
Verify new FICM voltage and plugs seated good.
Was truck up to operating temp in the video?
Did you rev it a couple times to "save" it from stalling or was that all on it's own?
Old Jan 2, 2014 | 07:48 PM
baller9409's Avatar
baller9409
it did that all on its own, its at the shop right now he's trying to replicate it but it seems to not want to do it when its there or when hes around. when it starts doing that i can plant the gas pedal to the floor and it doesnt do anything.
baller9409's Avatar
baller9409
2004 excursion, no codes
Old Jan 2, 2014 | 08:06 PM
Money-Pit's Avatar
Money-Pit
What are you using for gauges to read live data? What's your FICM voltage now after you replaced FICM?
Old Jan 2, 2014 | 08:14 PM
baller9409's Avatar
baller9409
his computer, not sure which one it is. but its at 48.5 for the 2 days i had it back..
Old Jan 2, 2014 | 08:20 PM
Money-Pit's Avatar
Money-Pit
Does it run like that only at cold start...or all the time, hot or cold? Do you know what the ICP is at idle?
Old Jan 2, 2014 | 08:29 PM
baller9409's Avatar
baller9409
does it at random, hot/cold. i have no idea, ive never had it hooked up when this is happening
Old Jan 2, 2014 | 08:36 PM
Yahiko's Avatar
Yahiko
You need to get a ScanGaugeII : Linear Logic - Home of the ScanGauge
Then load up the Xguages and someone will tell you what you need to
be watching other then the FICM voltage. Things like IPR & ICP data.
Also I would check the plugs to the IPR and IPC to see if they have any
oil on then. If they are wet you are going to have to replace the pigtails.
Sean
Old Jan 2, 2014 | 08:40 PM
baller9409's Avatar
baller9409
will do, ill have him send me the readings tomorrow for the ipr/icp and post that. ive kinda spent all my damn money on the thing in the last month, so the fact that its still doing this is driving me nuts. could oil getting on the plugs really cause this?
Old Jan 2, 2014 | 09:01 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Just a hunch, but I'm willing to bet that you have a short in your harness somewhere causing the rough idle and voltage drop.
