idle problem
Old Feb 19, 2011 | 01:43 PM
Kyle_KleinSS's Avatar
Kyle_KleinSS
idle problem
Guys I have been having an idle problem after driving. When I start it in the morning it is ok but after I drive and it warms up and I stop and throw it in park, the motor will sound and feel choppy. Im not sure where to look in to. Icp first maybe? My next thought was a sticking ipr. There is no oil in the icp plug. Any help is appreciated and thanks in advance!
Old Feb 19, 2011 | 05:59 PM
F350-6's Avatar
F350-6
Welcome to FTE. First off, how old is the engine oil and is it full? If in doubt, change the oil. Worn or improper oil can cause issues, especially when it warms up. And stay away from oil additives.
Next time it starts to idle bad, unplug the ICP with the truck still running. If the idle smooths out you need a new ICP sensor. If there's no change, it's not the ICP.
Old Feb 19, 2011 | 09:36 PM
Kyle_KleinSS
Changed it about a month ago only about 1.5k on it. Drove a few miles today and the idle was rough. Shut it off and unplugged it and drove it home with the icp sensor unplugged and when I got home it idled fine, I will try what you said tomorrow thank you
Old Feb 19, 2011 | 09:55 PM
Bigcat350's Avatar
Bigcat350
Did it have oil in the ICP connector or plug?
Old Feb 20, 2011 | 12:55 PM
Kyle_KleinSS
No oil in either. Just tried what he stated above when I just pulled in. When i touched the sensor it bogged down when I pulled it off it smoothed out. Shut it off and tried again and if i wiggled the sensor it killed the truck? Am I getting a bad connection? Its definitely an icp sensor problem should I order a new one. I am puzzled that moving the sensor bogged it and killed it
Old Feb 20, 2011 | 01:08 PM
tdpower's Avatar
tdpower
Sounds like a wiring/connection issue to me. You can get a new pigtail for the icp sensor if needed.
Try the tests in the first two tables of this link. ECSD - Injection Control Pressure (ICP) Sensor - 1994-1997 Power Stroke FAQ
Old Feb 20, 2011 | 01:20 PM
Kyle_KleinSS
Ok I will have to get my multimeter and check the connector. Ses light is never on unless I unplug it
Old Feb 20, 2011 | 04:07 PM
Kyle_KleinSS
Ok I tested the pigtail for voltage and ohms. The voltage tests all passed, on the ohm one The A test passed. The B test was .504k. The C test was 59.3k. My cousin helped he went to school for this but it has been 12 years so he couldnt remember exactly so he couldnt say if B and C passed. What are the values converted for B and C? . I am stumped. I think the pigtail is good but the sensor is bad am I correct?
Old Feb 20, 2011 | 04:58 PM
tdpower's Avatar
tdpower
Looks like B is out of range and would be 504 ohms. 1 k ohm = 1000 ohms.
Old Feb 20, 2011 | 05:07 PM
Kyle_KleinSS
Ok what would cause that and how do I fix it?
Old Feb 20, 2011 | 05:25 PM
tdpower's Avatar
tdpower
Probably a new pigtail would fix it. When you cut the wire back you can recheck the resistance on B and if it's still about the same it's further back toward the pcm. I'll see if I can find a part # for the pigtail. I know it's cheap at international but Ford sells a kit and is kind of expensive IIRC.
Edit:
International: ICP Connector
(International) 2501105c1
Ford repair kit (expensive, msrp $75)
5C3Z-12224-A
Old Feb 20, 2011 | 05:43 PM
Kyle_KleinSS
Ok where does that pigtail part plug in farther back? Is it in the loom thats covered up?
Old Feb 20, 2011 | 07:32 PM
tdpower's Avatar
tdpower
The pigtail is only plug and play on the icp sensor side. The harness side you have to splice it in.
Old Feb 20, 2011 | 09:18 PM
Kyle_KleinSS
OK gonna borrow an icp sensor of a guys truck here in town just to rule it out anyway. Then I will check into the harness
Old Feb 21, 2011 | 05:15 PM
Kyle_KleinSS
I think I got it, my pcm is an xle4 and i have pmt1 tunes on my php fu chip. Bill said it should run ok but when it is unplugged truck runs fine. Guess I gotta put my xle4 tunes back on it
cabloom300
Mar 22, 2019 10:00 AM
yidakimason
Sep 10, 2014 01:38 PM
figurhead
Apr 20, 2014 01:21 PM
1977scoutii
Sep 24, 2013 09:40 AM
strokin'_tatsch
Apr 5, 2010 09:51 PM
