1978 - 1996 Big Bronco
ignition module
Old Jun 25, 2003 | 11:16 PM
aggiebronco's Avatar
aggiebronco
ignition module
how can i tell if i need to replace my ignition module?
Old Jun 25, 2003 | 11:37 PM
greystreak92's Avatar
greystreak92
ignition module
In my personal experience, ignition modules just die. I have heard of bad modules manifesting as erratic idle or hard starting especially when warm. But I have only had them just die and the result is no spark...period.
Old Jun 26, 2003 | 12:44 PM
steve83's Avatar
steve83
ignition module
The Haynes manual has a very good detailed procedure to test it using a multimeter.
Old Jun 26, 2003 | 05:17 PM
WhëëlMå1's Avatar
WhëëlMå1
ignition module
I had to have the module replaced 5 times in our 89. It always just up and died (most of the time in the dead of summer, far away from my house).
Rich
Old Jul 1, 2003 | 03:09 AM
Kallie's Avatar
Kallie
ignition module
I just found out that was a recall on them thru FORD. My mechanic who worked at the local Ford dealship said it was because they failed and when they did they sometimes caused the truck to burn the ground.
Kallie
Old Jul 1, 2003 | 03:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
ignition module
The recall is for the TFI ignition module that fits on the distributor. The older fender mount ignition module fails also but the OEM modules seem to hold up well. Buy replacement MotorCarft modules, the other aftermarket modules are junk. Mount the MotorCraft unit on 1/4" spacers to allow cooling air under the module. I don't know of any good fix for the TFI module. I have seen a lot of TFI modules fail due to improper heatsink prep and installation.
The "burning to the ground" problem was an ignition switch problem if I remember right, not the ignition module.
Old Jul 1, 2003 | 08:17 AM
AlM's Avatar
AlM
ignition module
here is some more tfi info:
TFI Module Failure Inspection by Autotune
http://www.autotune.com/techtips/ford.html
TFI Relocation (see #10) by the corral
http://www.corral.net/20anngt/speed.htm
Old Jul 1, 2003 | 09:14 PM
aggiebronco
ignition module
i was thinking about pulling out the whole igniton system and replacing it with the old style points and condenser. how do i do that, or would it be cheap to put a new iginition system aftermarket or whatever. please help i missing mudding in my truck
Old Jul 2, 2003 | 12:43 AM
mrwizard's Avatar
mrwizard
ignition module
Points? Yuck. If you want to put in a new system, put in a new system, not one with technology that was phased out over 20 years ago.
Old Jul 2, 2003 | 12:44 AM
aggiebronco
ignition module
ok, well what kinda system would you recommend
padlikehel
Mar 19, 2010 07:57 AM
tygarcia
19
Jan 29, 2010 08:00 PM
Lngbeard
Jan 27, 2008 01:23 PM
Dutch123
15
Nov 27, 2007 03:16 PM
hotrod
Electrical Systems/Wiring
Oct 17, 2000 09:52 PM
