I think I have only seen one post on determining the health of the water pump from a flow perspective. In that post, it was discussed to watch the flow through the hose that returns coolant to the degas bottle. It was stated that the flow should be a steady and fairly strong stream. Who knows what that means!
I have considered rigging up a tee for the water pump discharge so that I could watch the pressure immediately off of the pump discharge, but I have not ever done it. I have the parts, but can't get motivated. Main reason is that I wouldn't know what to do with just one data point ..................
Are you sure that your ECT and EOT sensors are both accurate?
It will certainly be interesting to see if a new water pump would change your readings!
After a 72 hour cold soak my EOT sensor reads 2.5* higher then the ECT sensor.
When the engine is warming up the coolant temp leads the oil temp by about 10* until the thermostat opens, at that point the oil temp slowly passes the coolant temp.
Might want to determine which sensor is off and change it out, but a 2.5 degree off set isn't much.
Do you have a coolant filter? That is usually tied into the heater hose (supply) and returns flow to the degas bottle. Maybe another way is to simply observe how well your heater works on a really cold day to see if it is getting good flow (along the lines of what Bullitt was suggesting).
No coolant filter. I've debated putting one on. Coolant is flushed every 1.5 years and I've never had any debris in it. Truck has 62k on it so coolant has been flushed every 12k. The heater gets so hot it can burn my feet through my shoes. So maybe I am getting good flow.
I will test my oil and coolant sensors against the trans and IAT2 sensors and post the results.
I wonder if you could remove the vacuum from the heater control valve and see if the flow through your heater core (with the blower off, so that it isn't removing any heat) would affect your ECT or your ECT / EOT differential? I guess what I was thinking is: If the coolant flow is marginal to begin with, then routing more coolant flow through the heater core would probably rob it from somewhere else. Maybe that would show up in a slightly (maybe noticeable) higher ECT / EOT differential .... ???
OK guys, had a chance to work on the truck tonight.
It was time for another oil change, so I broke my routine. Normally I loosen the oil filter til it pops up and just leave it there to drain. Well, in a hurry I yanked the filter out to find it was dry.
I pull out the flashlight and look in the filter base to see nothing under the oil cooler bypass cap. I tear out the standpipe and the bypass cap to make sure. Nothing.
In a panic I look around the bottom and think to myself that my oil cooler ate the valve. I head over to my spare parts to start a search. Turns out, when I had all parts layed out on a table installing a new oil cooler, egr delete, blue spring, etc., the valve fell out and I chalked it up to being the old brass valve in the fuel pressure housing, I tossed it in the bag and never looked back.
I finished up and took her for a ride. Started right up after about 2 seconds of cranking. Drove for about 1 hour to find my deltas of 6. My ECT was 184* and EOT was 192*.
Well now I'm much happier. And I figured my water pump must be fine. I feel like crap, but have a sense of relief.
Now I guess it will be time to tackle the STC fitting and change out the oil cooler base gasket.
Thanks for the replies and ideas.
Looks like I need a new one. Its a new OEM bought in April last year. It has 2500 miles it. I think my original one held higher temps. I can watch the coolant temp come up to 192* and then drops down and settles in between 184-186.
