TPS Setting
Old Dec 30, 2013 | 09:43 AM
ungerp's Avatar
ungerp
TPS Setting
Does anyone know what the normal tire pressures are so the TPS will not alarm? The sticker on the door says 65 front and 80 rear for my F-350, but I think this is a bit high when empty or not pulling trailers, etc.
Additionally, is there anyway to adjust the TPS settings?
Old Dec 30, 2013 | 09:49 AM
djousma's Avatar
djousma
Your dealer can change the settings, if they choose too. some do, some do not citing legal issues. I had mine changed to 60PSI all the way around, but had to sign a release form to be able to do so. Some of the Tuner's can also change/turn it off too. Unloaded, I run 65PSI on all tires.
I agree 80psi in the rear is way to firm unloaded, and will cause premature tire wear.
Old Dec 30, 2013 | 05:42 PM
Romeo Scorpion's Avatar
Romeo Scorpion
I'm not sure about the fronts, but the rears will trigger the low tire pressure light at anything less than 60 psi. You then have to refill them to 75 psi or higher to clear the light, after which you can reduce the pressure to anything above 60 psi.
I set my rears to 63 psi on a near 0 degree day. Gives a very good ride and it shouldn't ever go below 60 psi unless it gets to -25 degrees or colder. I leave the fronts at 65 psi.
Old Dec 30, 2013 | 06:22 PM
Fontana's Avatar
Fontana
Are you sure it says 65 front and 80 rear? 80 rear suggests a dually if I'm not mistaken. Mine has been as low as 62 front and 70 rear without TPMS warning. I think the threshold is 60 psi. The TPMS should have separate limits for DRW.
Old Dec 30, 2013 | 08:05 PM
Romeo Scorpion
65 front, 80 rear is what's on the door pillar sticker of my F-350 SRW crew cab 4X4.
70psi won't trigger TPMS warning from rear, but below 60 psi will. I'm guessing the fronts could go down to 50 before a warning occurs.
Old Dec 30, 2013 | 09:16 PM
marchare011's Avatar
marchare011
Dually's don't have TPMS.
Old Dec 31, 2013 | 06:30 AM
EO2SeaBee's Avatar
EO2SeaBee
Same here. 65 front, 80 rear.
Old Dec 31, 2013 | 11:36 AM
ungerp's Avatar
ungerp
Yes, this F-350 SRW Supercab is 65 and 80 on the door pillar. I will try reducing the fronts and also the back a few pounds at a time. When empty and 80 in the rears I only ride on about the center 4 inches of tire.
Old Dec 31, 2013 | 12:47 PM
System's Avatar
System
Prolocutor
I had my dealer lower my rear set point as well. It was a small battle, but an email to the owner cleared it up quickly. This also helps during tire rotation so you don't have to relearn location.
Old Dec 31, 2013 | 01:21 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
That tire sticker is only there to advise you as to what tire pressures to run at maximum GVWR.
Old Dec 31, 2013 | 01:47 PM
doczenith1's Avatar
doczenith1
It is my understanding that the threshold for the TPMS sensors is set at 75% of the recommended 65psi front and 80psi rear pressures. I like to run my rears lower than my fronts when unloaded so I retrained the system and told it that the fronts were in the rear and the rears in the front. I aired down to 80% of recommended and after a few days the light came on so I went to 85% which puts me at 68psi for the front tires and 55psi for the rears and have not had the light come.
Per Michelin and my actual axle weights I can go even lower without safety issues.
Rustyfan21
Feb 9, 2018 04:32 PM
beeser
May 20, 2010 07:14 PM
ecrailings
15
Oct 18, 2006 03:01 PM
jroan
Apr 2, 2005 08:34 AM
v10kenj
Sep 16, 2003 07:58 PM
