rear tire pressure
Old Oct 17, 2006 | 09:39 PM
ecrailings's Avatar
ecrailings
rear tire pressure
I was wondering what you guys feel is a safe rear tire pressure for an unloaded truck. They had mine set at 80 psi which made it ride rougher than a track car. I lowered it to 60 and it is ALOT better riding. I was wondering if I could go lower safely.
Old Oct 17, 2006 | 09:41 PM
empiretc's Avatar
empiretc
when i got my new tires, they put 50 in all around. I ran that way for a while, but now I run 60 in the front and 65 in the back. Depends on tires. I run 10 ply 265/75/16.
Old Oct 17, 2006 | 10:01 PM
piotrsko's Avatar
piotrsko
I run 60 front and 65 rear also in an '00 CC long bed. went through 1 st set of tires at 50psi F & R and noticed a bit of edges wearing out about 10000 miles sooner than the middles on 60,000 worth of tire miles. So far the tires mic the same depth to .001 all across the tread with 30000.
Old Oct 17, 2006 | 10:50 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I run 80 psi with the camper in and 6o-65 unloaded
Old Oct 17, 2006 | 11:22 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Yeah, 80 psi will reduce wear and rolling resistance but ride like it is on rails. I've found that I get a certain amount of hop or imbalance in the rear when driving with higher pressures. Lower it and the ride is good but wear increases. Yay.
Old Oct 18, 2006 | 04:43 AM
ecrailings's Avatar
ecrailings
Mine ia a CC SB. At 80 it would bounce my helper in the back out of his seat, and he is a big guy!
Old Oct 18, 2006 | 06:24 AM
rusty350250's Avatar
rusty350250
mine is a sc diesel with 285s on stock rims and i run about 40 in the front and 35 in the back. the best way to find the best psi is the chalk method. draw a line on your tire and drive it 20 feet see wear the wear is and adjust the psi acondingly(middle only lessen, outside only add)
Old Oct 18, 2006 | 10:04 AM
jrciii56's Avatar
jrciii56
Here is my experience with tire pressures. I run more in the front than in the rear. I will add about 5psi if towing to the back tires. Right now I have 65 front and 60 rear. I monitor how my tires wearby using a tire depth gauge to measure the tread depth. If the outside of the tires are wearing more than the inside then I add pressure. If the inside is wearing more than the outside then I take pressure out. I have gotten great wear on all my tires doing this. I don't know if you will believe me or not but my grandfather got 107,000 thousand miles on a set of Michelin LTX M/S on his 1997 F250 extended cap!!!
Old Oct 18, 2006 | 10:29 AM
PA_Ford_Man's Avatar
PA_Ford_Man
Here's an interesting question - How do the Engineers arrive at the tire pressure levels posted on the Driver's door? This obviously has to have some sort of basis. Is it for safety?
I don't know, but I remember something about SUV tire pressures allegedly causing accidents/injuries and I believe it was involving Ford and BFG tires. I think the end result was to stick with the pressure posted on the door label.
I am following the label pressure for the front and 65 rear (Unloaded), 75 rear (Loaded).
Old Oct 18, 2006 | 10:43 AM
shenders99's Avatar
shenders99
60 in the front, 65 in the rear DRW.
I grew up in southern california and am here now visiting. Anyone that has ever driven in southern california know how much hell the freeways are in a 3/4 or 1 ton. Even a 1/2 ton is pretty bad. Only place in the country like it!
Old Oct 18, 2006 | 11:18 AM
sneak's Avatar
sneak
I have to admit that I run 65 in the front and 35-45 in the back, it all depends on the shape and wear patern of the tire. I do inflate to 70 or 80 when I do tow, but that's usually huge 23.5 ton loads around the farm. Heck, I even up the presure if I'm hauling my 4 wheeler.
Old Oct 18, 2006 | 11:51 AM
wlihntr's Avatar
wlihntr
why do so many of guys run more air in the rear tires compared to the front while unloaded? there is quite a bit more weight in the front if unloaded. i have 285/75-16's and unloaded run 54 front and 46 rear
Old Oct 18, 2006 | 12:11 PM
MTDewX's Avatar
MTDewX
60 in the front and 50 in the back, which makes it wear the best on my tires, but it really depends on what tire you running.
Old Oct 18, 2006 | 12:38 PM
sneak's Avatar
sneak
We have had four F-350's running 265/75R16LT Cooper H/T's and we allways had a problem with the midle of the tire wearing faster than the outside because we never did any hauling. So we dropped the rear presure to 30-35 on used tires with the poor wear patern and we run 45 on new or non effected tires. I also plan to run 40 in the rear on my up coming Cooper S/T-C's.
Old Oct 18, 2006 | 01:23 PM
zontral's Avatar
zontral
I run 60 in the front, 65 in the rear, if im towing i'll put a little more in the rear.
