Lowering tire PSI
Old Feb 9, 2018 | 10:55 AM
Rustyfan21's Avatar
Rustyfan21
Lowering tire PSI
I have a 17 F250 Super Cab/Long Bed, 6.2L, RWD with no modifications to the suspension running Continental LT 275/65 R18's. Currently the tire psi is set from the dealer at 60psi in front and 70 at the rear. Can I safely lower the tire psi to improve handling and ride characteristics. With the pressures as it currently is, the rear of the truck has a tendency to bounce around during rougher sections of the road almost like its a bit loose as any nascar driver would say. I don't tow a lot and able to bring the pressures back when needed to tow and or haul. I am comfortable with adjusting the monitors through FORSCAN. Is this a safe thing to do and what would be a good recommendation for tire pressures? Also if I adjust the pressure monitors will I need to readjust them when I pressure up or are they just a low pressure monitor? Thanks
Old Feb 9, 2018 | 03:18 PM
Buliwyf's Avatar
Buliwyf
try 60 in the rear. If it trips the Obama light, you'll have to go to 80 until it clears.
Old Feb 9, 2018 | 03:42 PM
mhoefer's Avatar
mhoefer
Or adjust your thresholds to 60 60 front and rear with Forescan. Dealers wont touch this but thats what I did. 60 front and 65 rear for mine.
Old Feb 9, 2018 | 04:31 PM
6.2caribou's Avatar
6.2caribou
I've found that I can lower mine to 55-56 cold. A lb. or 2 less than that and the alarm is tripped.
Old Feb 9, 2018 | 04:32 PM
backtrack2015's Avatar
backtrack2015
Not that it matters, but I think the TPMS law originated near the end of the Clinton era and was finalized and implimented during the Bush years.
N600
Large Truck
Apr 6, 2014 08:59 PM
ungerp
6.7L Power Stroke Diesel
Dec 31, 2013 01:47 PM
beeser
May 20, 2010 07:14 PM
crapr6
16
Jun 21, 2007 12:45 AM
v10kenj
Sep 16, 2003 07:58 PM
