Sway bar and steering linkage problem
Old Dec 28, 2013 | 11:44 PM
Chingo813's Avatar
Chingo813
So I have a 1986 f150 that I've just freshly repainted and dropped that's were I ran into a problem I got the djm 3/5 drop kit the rear flip kit went in fine but when I did the front I beams and dropped the truck on the ground the sway bar is rubbing on the steering linkage has anyone run into this problem if so how did you fix it any help would be appreciated
Old Dec 29, 2013 | 09:26 AM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
I have, on my 95. i went Dream beams AND lowering springs. Dont fret, there is a way around it.
First off, unbolt the swaybar for now. no good will come out of driving it this way.
The best way i found to do it is to physically flip the swaybar and use swaybar links off a 1999 Ford F250 super duty truck. sounds crazy, but it's still working after 15,000 miles. havent hit anything yet.
Old Dec 29, 2013 | 09:40 AM
Chingo813's Avatar
Chingo813
Thanks I'll do that for now unbolt it till I get those links
Old Dec 29, 2013 | 09:46 AM
Bootlegger's Deluxe
yup, it seems pretty odd, but heres the theory.
you take the bar off, you flip it upside down (so the left side is now the right) you bolt it on a certain way. you do the hokey pokey. you use the crazy long Super duty links. you then fret about ifthe bar hangs too low (it doesnt, unless you're off roading, i have never hit anything with mine)
i'm going to go look at my truck now so i can tell you the exact mounting.
Old Dec 29, 2013 | 11:01 AM
Chingo813's Avatar
Chingo813
Thanks man appreciate it very much
Old Dec 29, 2013 | 08:40 PM
Bootlegger's Deluxe
Dangit, i forgot to look today. Are you in a huge hurry? if not, i'll find a pic of what i'm talking about.
Old Dec 29, 2013 | 09:04 PM
Chingo813's Avatar
Chingo813
Na man I probably won't touch it again till this weekend I got the 99 sway bar link tho just couldn't get it to work but when ever you can get to it it's fine thanks
Old Dec 29, 2013 | 09:25 PM
Bootlegger's Deluxe
OK man, heres what i have.
Remember, this is on a 95, but it should transfer, 95% the same.
unbolt the bar, and bolt the metal plate back up to the frame in it's normal direction.
Bolt the bar to the outside (front) of the angled plate. make sure to rearrange the bar so that the ends go UNDER the tie rod ends.
Attach links to go up to the mounts with bolts.
Heres a pic, not my truck, but the guy who told me of this.
Old Dec 30, 2013 | 05:02 AM
Chingo813's Avatar
Chingo813
Thanks man I'll try it after work today n let you know
Old Dec 30, 2013 | 10:42 PM
Bootlegger's Deluxe
So, Chingo, i have to ask....
Were/Are you like me, for the first month or so after slamming my 95, i was in awe of just how low the truck squatted.
Are you going through that phase?
Old Dec 31, 2013 | 04:32 PM
Chingo813's Avatar
Chingo813
Lmbo I ain't gunna yep I'm in that phase right now getting compliments here n there just soaking it in
macdiesell69
6.7L Power Stroke Diesel
Dec 16, 2013 12:16 AM
RKCORPS25
Nov 8, 2013 12:17 PM
ggadwa
Dec 7, 2012 09:28 AM
mylandscaper
Feb 8, 2010 11:40 AM
resonance530
Aug 26, 2006 12:20 PM
