My truck has had a lean on the front drivers side for a long time now. I've tried everything I could. So today I got under it disconnected the sway bar links from the bar, I then attached the side that was not leaning just fine. The side that has been leaning did not match up at all. I took my jack and jacked up the link to where it would meet the bar and it took care of the lean. However when I lowered the jack so did the truck. Is this a bent sway bar and I need a new one? Could this really be the problem? Also the screw from the link to the bar is going to need to be replaced its so flat and theads are done. Any suggestions.
No pics yet I will put some up tonight but no lift or leveling kit installed. I have a 3/4" -1" lean on the drivers side I will look at how to post pics
I have no idea. When i lifted mine, the front was equal for less than 24 hours then it sagged in the front left again. Guessing rear springs maybe, havent cared enough to look into it
