Time for new batteries? Update
Old Dec 28, 2013 | 01:15 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I'm thinking my 4+ year old batteries need replacing. What do you think? I've been doing some shopping this morning.
Old Dec 28, 2013 | 03:45 PM
the_auto_tech's Avatar
the_auto_tech
Generally it's regarded a set of batteries only lasts about 2-3 years in these trucks. From the looks of it I'd say you're due for a new set.
Old Dec 28, 2013 | 03:55 PM
jswartz84's Avatar
jswartz84
My factory Motorcraft batteries lasted 8 years, when it was time to replace them I went back with OEM. What brand are you using?
Old Dec 28, 2013 | 04:33 PM
Pete_H's Avatar
Pete_H
Besides the evidence from the gauges, the sound of that startup makes me want to drive to walmart for a battery exchange. Every 18 months or so mine sounds just like that.
Old Dec 28, 2013 | 05:45 PM
mhoefer's Avatar
mhoefer
What is the specific gravity measurement of each cell? Volts are not really telling you the complete story, low volts could be from alternator not working properly, the other is to load test separately. One bad cell out of both batteries will get you this lower voltage and likely won't allow full charging from the alternator either. Alternatively,p if the SGs are good in every cell, then you are going to need to look at alternator charging volts, should be 14.4 at first start, should go up to 14.8 as glow plugs shut off. If it's not hitting 14.8 volts on the alternator charge cable you have an alternator problem, until you solve this your taking a toll on the FICM, though your FICM is looking good now, the more starts at the low voltage he possibility of damage. If you do need an alternator, go with the Ford upgraded 140 amp at minimum, better still a DC power or higher amperage which will charge the batteries up better! protect the FICM.
Old Dec 28, 2013 | 07:26 PM
Mich6.0's Avatar
Mich6.0
The amp draw on these engines during start are high and batteries should be replaced before four years to protect the FICM. You might get longer life in warmer area's of the US due to limited glow plug use.
Old Dec 28, 2013 | 07:38 PM
69cj's Avatar
69cj
Totally disagree with that. Have never had more than 13.8 on the stock alternator, still original, and still original FICM with no problems. Everything stock.
Old Dec 28, 2013 | 08:03 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I would concur you are needing a set of batteries.
I'll add the OEM batteries in my previous 2005 lasted from Fall 2004 to early Spring 2008.
I have no real clue about my current 2006, however, it had a set of Motorcrafts that I replaced last year, if original would have made them 7 years old.
Josh
Old Dec 29, 2013 | 01:05 AM
amdriven2liv
Would never have noticed this issue if it were not for having a monitoring system of some sort in the truck.
Another reason to have something!
Old Dec 30, 2013 | 01:12 PM
amdriven2liv
Got new Batteries for the truck.
Here is the start,
Interstate Batteries.
Product ID: MTP-65
Cranking Amps: 1000
Cold Cranking Amps: 850
Voltage: 12
Capacity: 85
Termination: Common Code A
Weight: 45.4
Width: 7.5
Length: 12.00
Height: 7.50
Plates: 24
WET/DRY: W
$113.95 +tax for each.
Old Dec 30, 2013 | 03:43 PM
One Cylinder's Avatar
One Cylinder
I like replacing my batteries with Die Hards due to;
Usually a better product than OEM
Sears Auto Centers in all major cities
Opened 7 days and until 9pm.
pirschwagon
Jun 29, 2019 05:57 PM
moose79
22
Jan 25, 2019 02:14 PM
timmyboy76
19
Apr 23, 2014 03:58 AM
Bender99
27
Nov 25, 2010 09:43 AM
theologian
21
Nov 14, 2003 07:02 PM
