I can't remember where the horn was mounted. I thought it was on the outside of the Rad support on the passenger side. I have a new rad support and there are no holes for the horn
I also need to find the feed wire to the horn.
A pic sure would be nice.
Thanks in advance
If you have a single horn, it was mounted on the inside of the radiator support, above the voltage regulator. If you have the dual horn option one horn is mounted in the stock location and the second horn is mounted in about the same position on the driver's side.
The wire is a yellow w/ green trace that plugs into the same harness that plugs into the voltage regulator. With the dual horn option a wire also runs from the horn on the passenger side across the front of the radiator support to the second horn.
