89 e 150 stalling
Old Dec 26, 2013 | 10:38 AM
salembox's Avatar
salembox
89 e 150 stalling
I have a 89 E 150, 5.0 stalling after running idle 20 - 25 min. Have replaced fuel pump & relay, tfi, coil without change in symptoms. Could it be the pick up stator in the distributor or a another problem?
Old Dec 27, 2013 | 09:32 AM
subford's Avatar
subford
Could be that or the EEC Computer.
Both have been known to do that.
When it dies check for spark.
If you have none unplug the SPOUT and if spark returns, if it does it is the computer.
Could also be the fuel pump(s) causing this problem.
Old Mar 17, 2014 | 09:01 PM
salembox's Avatar
salembox
After replacing distributor the problem recurred in about 7 days. After further reading on the internet i chose to replace the idle air control valve. So far it seemed to do the trick. No more stalling at idle. Keeping my fingers crossed.
Old Apr 19, 2014 | 10:48 PM
salembox's Avatar
salembox
After replacing distributor, tfi, coil, idle control, fuel pump, relays, clean egr and throttle body the problem kept recurring. As part of after thought, I remembered that I replaced the dual tank canister on the frame with one from the junk yard to fix a fuel leak problem. This was causing a blockage which stalled the engine. after by pass of canister, no more problem
myveryfirstford
Apr 12, 2011 12:31 PM
Fordnorth
1997 - 2003 F150
Sep 13, 2005 02:54 PM
clydedog66
Aerostar
Mar 20, 2002 10:56 AM
canadianfordman
Feb 15, 2002 05:33 PM
