Sponsored by: Auxito
Idle Speed Control Bypass Value Problem
Old Aug 31, 2005 | 02:53 PM
Fordnorth's Avatar
Fordnorth
Question Idle Speed Control Bypass Value Problem
Hello: I have a problem, that when my 1990 F150 is driven a few Kms it will not idle or idles erratically. Could this be the ISB Value. I have cleaned it twice. I have also check to see if the EGR value moves. Checked engine codes. Do not want to replace ISB Value because of price! Could I have a fuel pump problem? Appreciate any help. Thanks.
Old Sep 4, 2005 | 08:57 AM
projectSHO89's Avatar
projectSHO89
Replace it. It's 99.9% likely to be your problem. Just went through this on my SHO and have seen it numerous times on many other Fords of the same era. Cleaning the mechanical portion of the valve sometimes helps, but not always.
Unhook the battery while you're wrenching it so that the computer resets. Once everything is back together, the computer will releardnthe idle control strategy.
Steve
Old Sep 13, 2005 | 02:54 PM
Fordnorth's Avatar
Fordnorth
Thanks Steve: I did replace the value last weekend and it did not stall today. So it must have been the problem. And yes I did clean it a few times and it still did not work!. I was reading other peoples problems with this same value and it seemed like a common problem.
Skzuk
Feb 24, 2013 07:00 AM
Engalwood
Large Truck
Sep 7, 2010 07:17 PM
Motorhead-42
15
May 14, 2007 07:34 PM
bobby_rogers
Modular V8 (4.6L, 5.4L)
Aug 11, 2005 03:13 PM
WXboy
Mar 18, 2004 09:27 PM
