CRANK NO start!!
Old Dec 26, 2013 | 06:44 AM
Tugly's Avatar
Tugly
Good job on solving it and reporting back.
As I was reading the exchange, these were the thoughts in my head:
The ICP bounces around because the engine crank speed effects the pumping action of the HPOP, the IPR is very slow to react to situations, and the OBDII port is even slower to report those situations to your scan tool. "Too much" ICP and IPR is OK when cranking.
You checked all the "testable" elements needed to start, except one. You forgot to look for the Fuel Injector Pulse Width. If you had checked that, you would only see the Sync Signal of 0.6 ms through the whole cranking cycle. With all other elements meeting minimums, the CPS would have popped as a suspect... but the 150 RPM reading confuses me.
Old Dec 26, 2013 | 09:45 AM
440wagonr/t's Avatar
440wagonr/t
yup she runs good guys. I'm gonna change the injector here in a minute and she should run smooth.
i did check the IPW and it was .8 cranking and sometimes 1.6
i have a friend who preaches these trucks.
he stopped by and had a cam sensor in his glove box lol
thanks guys!!
Old Dec 26, 2013 | 11:04 AM
Tugly's Avatar
Tugly
Originally Posted by 440wagonr/t
...i did check the IPW and it was .8 cranking and sometimes 1.6....
Ah... there it was. The CPS was sending a partial signal and cranking should yield a significantly longer pulse width. If you check it while cranking now, you'll see what I mean.
edo488
15
Aug 21, 2017 10:57 PM
f350project
Sep 1, 2014 07:09 PM
Jibbles41x
May 13, 2013 09:52 PM
bulla
Mar 9, 2011 03:36 PM
soup2nutz
Nov 25, 2006 05:34 PM
