E40D problem
Old Dec 25, 2013 | 06:29 PM
1994F2507.3L's Avatar
1994F2507.3L
E40D problem
I was driving home today coming up a hill all was normal, as I crested the hill overdrive light started flashing, no limp mode or seemly unusual operation of trans, temp didn't get over 140 tops. I went ahead and drove it home and didn't have any issues really, shifts seem a little more firm from 1 to 2 but that may be in my head, are there any common issues with these that cause the light to come on but no limp mode?
Old Dec 25, 2013 | 07:00 PM
kyle ritsema's Avatar
kyle ritsema
Have the codes check if the od lights flashing is probably a electric probably post the codes
Old Dec 25, 2013 | 07:17 PM
osu711's Avatar
osu711
Mine did that a few weeks ago then the light stopped flashing eveything seemed fine. About a week later it started doing it again, went away and has yet to come back and I have still yet to pull codes. DONT DO WHAT I DID AND WAIT FOR CODES
Old Dec 26, 2013 | 12:20 AM
Thor'sHammer's Avatar
Thor'sHammer
Scan it. If you get a P1725 it means the converter clutch is slipping. It may be time for a converter before it shreds. I had replaced mine this summer with a high capacity one and the new one cracked the lock apply piston, so now I get to change it again.
Old Dec 26, 2013 | 06:04 AM
1994F2507.3L
The code I have is P1728
Old Dec 26, 2013 | 07:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That means the converter clutch is slipping. P1725 was a typo.
Old Dec 26, 2013 | 08:04 AM
1994F2507.3L
Well I was looking at suncoast rebuild kits for the Trans as well, I figured since that kit is 500 and I'll have to pull the Trans for the converter I might go ahead and do it while it's out.... Have you guys used the suncoast extreme kit? I'm looking for one that will hold up to 4-500 HP for a reasonable price. I'm a mechanic (engines) and my school has a transmission shop that I can use and my program director has done his own 4r100 before. I'm just looking to get parts that will last when I build my engine
Old Dec 26, 2013 | 11:56 AM
1994F2507.3L
Also there torque converter is 1300$ this is gonna be an expensive venture
Old Dec 26, 2013 | 05:02 PM
427 fordman's Avatar
427 fordman
In order to be SURE the trans will hold 4-500 hp, you need to spend closer to 5k and buy one from one of the main builders, racer x, bts, john woods, etc. Racer x sells a real good converter for 900ish. I've got that converter and a fairly heavy duty rebuild. However, my trans isn't as good as any one listed above for sure.
Old Dec 26, 2013 | 05:47 PM
1994F2507.3L
What all do they have in them to make them special?
Old Dec 26, 2013 | 06:54 PM
427 fordman
I don't know what is all done. I know there are case modifications done. I don't know the reason or what all they do though.
Old Dec 28, 2013 | 05:43 AM
1994F2507.3L
I know certified transmission sells there high end rebuild for around 4000, there a local company here in Kansas city have any of you heard of them?
rednekrebel28
41
Mar 30, 2023 08:28 AM
RÖENTGEEP
Mar 23, 2018 01:49 PM
E450 newbie
Dec 18, 2015 05:40 PM
CMOS
Dec 13, 2008 09:18 PM
gotama
Nov 15, 2004 09:29 PM
