time for a starter
Old Dec 25, 2013 | 05:45 PM
bryanlindborg600's Avatar
bryanlindborg600
time for a starter
well my starter has been "tired" for awhile. what do you guys recommend i get?
Thanks
Old Dec 25, 2013 | 05:54 PM
bridgeman's Avatar
bridgeman
same here..
Old Dec 25, 2013 | 06:34 PM
ReBilld's Avatar
ReBilld
Some guys replace the OBS starter with the high-torque Super Duty starter.
Old Dec 25, 2013 | 06:37 PM
dougbrown's Avatar
dougbrown
If u look up a remey new starter the Obs and sd are the same number.
Old Dec 25, 2013 | 06:42 PM
ReBilld's Avatar
ReBilld
Really?? I've never done it, but I figured they were different.
Old Dec 25, 2013 | 06:53 PM
dougbrown's Avatar
dougbrown
Yes I'm almost positive. Used the lifetime warranty of my dads 2000 7.3 starter to replace my Obs one. Got me a freebe!
Old Dec 25, 2013 | 07:00 PM
LeoJr's Avatar
LeoJr
I'll be paying attention to this as I want to be prepared when mine fails. My alternator failed catastrophically and unannounced forcing my to buy one from napa rather than exploring options.
Old Dec 25, 2013 | 07:02 PM
ReBilld's Avatar
ReBilld
LOL!! Cool
Old Dec 25, 2013 | 07:37 PM
pjwoolw's Avatar
pjwoolw
If there is a shop local to you than can rebuild the one you have thats the way I would go. The is, IIRC, a higher torque Mitsu starter available also. An option opposed to going to a Denso two bolt.
Old Dec 25, 2013 | 07:47 PM
Ford4Life7.3's Avatar
Ford4Life7.3
There are two different starters. SD also uses a gear reduction starter. I have the gear reduction starter on mine. One has two mounting holes and the other has 3, but they bolt up the same.
Old Dec 25, 2013 | 09:34 PM
Krisx125's Avatar
Krisx125
Replacing the obs starter for a sd starter is the best!
Old Dec 26, 2013 | 09:39 AM
JCart's Avatar
JCart
Yes SD gear reduction starter is the way to go, two bolts and might have to enlarge the starter (at starter) solenoid post wire connector so it slides on the post. Spins way faster for quicker starts and is generally less expensive than OBS starter, least where I live.
jrc
Old Dec 26, 2013 | 06:32 PM
bryanlindborg600
well, i threw on a sd starter today and man, that thing spins like no other, fast as all he!!, im waiting to see how much nicer it starts in the cold tomorrow! anyways Thanks guys!
Old Dec 26, 2013 | 10:55 PM
C350CREW's Avatar
C350CREW
Did you have to mod anything to make it work? How did the cost compare to the obs starter?
Old Dec 27, 2013 | 12:07 AM
bryanlindborg600
Just had to drill out the small wire eyelet that goes to the solenoid.. Very simple and well worth it. Just my opinion but I'm very happy with the starter. As far as cost goes I'm not sure I didn't even price out the obs starter.. Sorry
