Dash/Tail/Park Lights Not Functioning Properly
Old Dec 25, 2013 | 05:05 PM
1972RedNeck's Avatar
1972RedNeck
On my '90, the tail, park, and dash lights aren't working correctly. When the headlight switch is pulled to the first position, nothing happens. When pulled all the way out, the headlights illuminate - nothing else.
But, if the switch is held between the two positions, a click is heard under the hood and the tail, park, and dash lights illuminate and work perfectly.
I tried a new FoMoCo headlight switch to no avail. All the fuses are good.
Suggestions?
Old Dec 25, 2013 | 10:10 PM
Arps 6.9's Avatar
Arps 6.9
sorry for the excitement but, I'M HAVING THE SAME PROBLEM. Which kind of sucks because I was going to try a new switch tomorrow, all my fuses are also good, same click in intermediate positions. With just headlights.
Old Dec 26, 2013 | 05:14 AM
fhafer's Avatar
fhafer
The first thing I would do is clean and re-tighten the battery grounds. Make sure the battery terminal connections are clean and tight. The next step is tedious...pull one fuse at a time and see if any single circuit has an issue. If it doesn't change the problem then replace the fuse and move to the next. I suspect a tail light or headlight socket is going to ground. You can clean and inspect them first if you choose...buy a tube of dielectric grease and use it on all the connections to prevent corrosion/high resistance connections in the future.
My opinion. Good luck.
Old Dec 26, 2013 | 11:09 AM
tecgod13's Avatar
tecgod13
What shape was the wiring harness when you swapped the switch?
The trucks are known for overheating the switch causing it to fail, and also to melt the plastic on the wiring harness connector.
You may have gotten a bad switch if the new one is doing the same as the old one, maybe return it and try another new one? But definitely check all the grounds as well!
Old Dec 26, 2013 | 12:50 PM
Arps 6.9's Avatar
Arps 6.9
Well the switch is not the problem, the positives on the sockets are ground, so there is a short somewhere, I don't know how to find a short unfortunately.
Old Dec 26, 2013 | 01:03 PM
1972RedNeck
Luckily, mine was an easy fix. I pulled all of the the fuses and closely inspected them again. They all looked good. Grabbing at straws, I took the test light and tested each fuse with it. The instrument lighting fuse was bad. It still looks good though.
Somehow the dash/tail/park light circuit was being back-fed by the headlight circuit when the switch was held in just the right spot.
Old Dec 26, 2013 | 01:06 PM
Arps 6.9's Avatar
Arps 6.9
I tested all the fuses with a tester the first time, well that sucks I was looking for an easy fix
Old Dec 26, 2013 | 07:47 PM
tecgod13's Avatar
tecgod13
What do you mean by this? The positives at what socket? If you're testing at one of the lights, the positive will ground out through the through the other bulbs in the circuit.
Did you try a new switch? While replacing it, look at the connector for the switch harness and check if its melted or something is shorting out there. Mine was all deformed and one of the connections was loose, I had to use some small pliars or a screwdriver to push it into place at first. I ordered a new connector and wired that in shortly after.
Steves55
18
Apr 27, 2010 01:45 AM
soulwinnerrj
Electrical Systems/Wiring
Oct 31, 2007 07:55 PM
franco99
1978 - 1996 Big Bronco
Feb 8, 2006 03:25 AM
palace_master
Dec 18, 2004 12:00 AM
slifer
May 16, 2004 06:00 PM
