C6 transmission
Old Dec 24, 2013 | 08:31 PM
Cman8469's Avatar
Cman8469
C6 transmission
I have a 73 xlt with a 390 engine it has a 3.70 posi rear end. I want to replace the 3 speed C6 transmission or is it possible to make the original C6 an overdrive transmission? Any help would be greatly appreciated.
Old Dec 24, 2013 | 09:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The only way to make a C6 an overdrive transmission is to add a Gearvendors overdrive unit which is expensive.
The FE series (390) engines have a unique bell housing bolt pattern so there is no off the shelf overdrive tranny that will bolt up.
There are adapters that will allow you to bolt one up but they too are expensive.
I would say that you're looking at close to $1,000 minimum for overdrive, that'll buy a lot of gas.
Old Dec 25, 2013 | 12:02 AM
DeepRoots's Avatar
DeepRoots
Since you are rebuilding the c6. why not toss in a wide ratio gearset:
Wide Ratio Gear Kit - Broader Performance
and change your rear ratio for better highway rpms.
Old Dec 25, 2013 | 12:18 AM
884x4broncoII's Avatar
884x4broncoII
1/1 final drive ratio is better for fuel millage if your rear end is matched to your cruising speed.
Old Dec 26, 2013 | 04:57 PM
Cman8469's Avatar
Cman8469
I checked on the price for the gear vender, your right mike that is steep. Right now the truck sounds really wound up tight at 80 mph, I just want more top end out of the beast. The truck has a lot of sentimental value to me because it was my fathers but I can't rob a bank to make it an every day driver like I want. The motor used to be a 360 , my dad changed changed it to the 390.
Old Dec 26, 2013 | 06:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I completely understand sentimental value, or as I spell it, $entimental. I'm currently pouring a butt load of money into my '73 because of it .
I did what DeepRoots suggested. I had Broader Performance build me a C6 with the wide ratio option and have a 3.00:1 rear.
The wide ratio gearset comes from the E40D.
Old Dec 26, 2013 | 10:55 PM
DeepRoots's Avatar
DeepRoots
another point of note.......
I found a used GearVendors for $500.
If you ever find one snag it. If I sell the car, it isn't going with it :P I'll just install the old driveshaft and tailhousing.
don77
30
Jan 29, 2009 08:23 AM
breakfree
Offroad & 4x4
Apr 3, 2007 07:33 PM
casey torfin
Sep 21, 2004 01:47 PM
elemint
20
Apr 3, 2004 05:32 PM
Chris_ce
Aug 2, 2003 08:54 AM
