lockout problem
Old Dec 24, 2013 | 10:04 AM
wahlturfcare's Avatar
wahlturfcare
lockout problem
U have a 93 f350 with the dana 60(dually) and noticed the front lockouts stopped working. I checked all the front u joints and they are still tight, front driveshaft seems to be kicking in and spinning transfercase works in all gears. Any ideas?
Old Dec 24, 2013 | 10:14 AM
mike Stansberry II's Avatar
mike Stansberry II
Manual or auto hubs? Jack up the front end with everything locked in and see if the front wheels spin by hand. might be the hubs are bad
Old Dec 24, 2013 | 10:20 AM
Conanski's Avatar
Conanski
I'll bet you have auto hubs.. which are well known to fail. Also note it's much more common for the U-joints in the front axle to seize up from lack of use than to wear to a sloppy loose condition, and a seized outer U-joint can interfere with hub locking.
Old Dec 24, 2013 | 03:52 PM
wahlturfcare
I have manual hubs. I did jack it up with 4 lo and hubs locked in and both axles are spinning freely. Any way of checking each lockout?
Old Dec 24, 2013 | 05:20 PM
danr1's Avatar
danr1
Not real clear, picked up one wheel tried them individually? or did both at same time, had them both off the ground then tried spinning the wheel?
If you're gonna do it that way you want one wheel off the ground both lockouts locked, try to spin the wheel in the air.
Problem with that test is if only one fails to lock either wheel would spin.
Lock the lockouts, reach around inside the wheel turn its axle shaft at the u joint, the hub should lock before you make the axle spin one full revolution. It might take more but should lock right in fairly quick and hear it when it does too.
Do the same test both sides, lock hub turn its axle shaft by hand.
If one or both fail to lock remove the lockout cap, you could find anything from missing parts to water damage, spring and or gear missing (say if its a "new to you truck") and or rust/corrosion preventing the gear from sliding freely in and out.
If find all gummed up take them all apart clean the parts and inspect for damage. Lightly grease gears/bearings/splines putting all parts back together, do not pack the lockout full of grease, medium light coating is all that is required.
If you live in the rust belt you might have to drill out the cap screws to remove the lockout cap, if find you do drill the heads out but do not damage the cap in the process. They caps are pricey a hardware kit with new caps screws is not.
Little RTV prevents that from happening again.....if you live in the rust belt....
Old Dec 24, 2013 | 06:17 PM
wahlturfcare
I did try it with both wheels off the ground and one at a time. Also, i did get the to lock iN earlier. But i still dont hear them clicking in or anything.
bkeese
Oct 23, 2014 01:47 AM
btacarlton
Apr 26, 2012 05:43 PM
muscletruck7379
Jun 16, 2004 05:55 PM
Berlinetta00
Offroad & 4x4
Apr 3, 2004 10:34 AM
PA F150 4X4
May 13, 2003 09:26 PM
