computer fried? (pic)
Old Dec 26, 2013 | 05:47 PM
chavist93's Avatar
chavist93
I haven't turned mine in to get the $50 core charge back yet. I may just keep it and have the caps replaced to have a spare. It looks perfect other than the one pictured above.
Old Dec 26, 2013 | 05:56 PM
danr1's Avatar
danr1
Have it repaired be sure and replace all the caps on it not just that one that looks bad now. It might be only one leaks but the others are not far behind, that and they might not work right or at all regardless of any signs of leakage at this point.
Old Dec 26, 2013 | 11:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Caps like that generally look swollen before they leak.
Any of them 20+ years old are suspect.
You may be able to find them at RadioShack. IDK.
DigiKey, Mouser or Newark for sure.
Old Dec 26, 2013 | 11:59 PM
PDR60's Avatar
PDR60
Mine was a bit worse than that and I fixed it. Pull the bad caps clean with alcohol and put it under a 3-5x glass. Look for burnt traces. If you don't have any then you can be pretty safe in fixing it. Cost is about $6 and an hours worth of solder time.
Old Dec 28, 2013 | 01:09 PM
chavist93's Avatar
chavist93
Just an update. The new computer fixed the stalling issue. I drove it for about an hour today and it did fine. Still has the high idle though. Its not very noticeable in gear, but its pretty high in park an neutral. I still think there is a vacuum leak somewhere that im missing.
Old Jun 8, 2014 | 03:17 PM
chavist93's Avatar
chavist93
I just wanted to update this thread for anyone using the search for a similar problem. Although I believe the computer needed replacing, I don't think it was the problem. About a month ago I had the same exact problem along with extremely hard shifting along with smoke at cold start. I replaced the mlps with the 95 style and all issues are resolved. I shifts like butter now, better that it ever has.
Old Jun 17, 2014 | 02:42 PM
drjoe171's Avatar
drjoe171
I got a guaranteed computer for my 91 for like 40 bucks
from pickapart?
They said they'd take it back if it didn't work, either itself or didn't fix MY problem.
Unheard of.
So I got it and it worked, fixed my old computer caps for like 10 bucks
and nice to have a spare for sure.
Old May 28, 2016 | 07:13 AM
reamer's Avatar
reamer
WHAT, a "TV Repair shop"???? heard about them and read about them in history books.....
Old May 28, 2016 | 08:57 AM
bigredtruck's Avatar
bigredtruck
just did that repair myself:
https://www.ford-trucks.com/forums/1...tor-valve.html
Will Joyce
Nov 6, 2018 05:48 AM
88PONY
25
Mar 15, 2008 06:40 PM
shooter05
Aug 20, 2007 10:48 AM
kermitthefrog
Jul 10, 2007 06:29 PM
tres01expy
Jun 8, 2003 02:46 AM
