Help with parts
Old May 28, 2016 | 10:12 AM
Teel51's Avatar
Teel51
Help with parts
I have a 1995 ford F 150 4x4 Eddie Bauer edition and changed rtont brake rotors which is hub and rotor assembly. They made some changes on this vehicle in 5/95 . This has automatic hubs and I broke one of the clips that has a insert that goes into a spline then clips around the front of the bearing nut to keep it from backing off. Where can I get this clip for a reasonable price. The ones I have located are 20 to 30bucks apiece. A little ridiculous on the price. Also there is a nylon washer in between the 2 metal washers that I need to replace.
Old May 28, 2016 | 11:53 AM
bashby's Avatar
bashby
Try googling the part #? Junkyard?
You can seperate the rotor from the hub. No need to replace the hub.
boggerted
Nov 19, 2008 04:41 PM
Baer
Apr 14, 2007 06:14 PM
alz
Apr 17, 2005 07:49 PM
The Tree
1978 - 1996 Big Bronco
May 12, 2004 09:29 PM
DJack
Jan 11, 2004 07:57 PM
