RABI
Old Dec 23, 2013 | 12:36 PM
mike Stansberry II's Avatar
mike Stansberry II
Unhappy RABI
1988 F150 4X4 5.8ltr C6
The abs lights up after I hit 41-42mph. The rear brake lights are dimly lit when I start her up in the mornings. I replaced the speed sensor and the abs hydraulic unit (rusted couldn't bleed\replace line).any ideas?
Old Dec 24, 2013 | 08:41 PM
dixie460's Avatar
dixie460
Can you pull fault codes from the RABS controller?
Sounds like a possible ground issue.
Maybe someone else will chime in after the bump.
Old Dec 24, 2013 | 09:43 PM
Ranger80's Avatar
Ranger80
If the brake lights are lit at all it'll cause a problem. The RABS module should click within a couple seconds if starting, and will not anytime the brake lights are on. If they are dimly lit, I'd bet on bad grounds and current flowing through them to ground to the brake lamp circuit. Check and clean your grounds, I'm betting the problem will go away. Only other thing I can think of is your brake light switch.
Old Dec 24, 2013 | 11:25 PM
Island Time's Avatar
Island Time
I'd pick the brake switch. Bad grounds will cause some weird problems, but I don't think they'd cause the brake lights to be lit when the brake peddle isn't depressed. Either that, or a short between positive side of the brake light circuit and something else on the positive side of the battery.
Old Dec 25, 2013 | 07:35 AM
mike Stansberry II
Thanks for the help everyone. I'll start with the switch when its a little wormer out.. high of 22 today
Old Dec 25, 2013 | 01:38 PM
Ranger80's Avatar
Ranger80
It seems odd doesn't it? I could be wrong but I had the same issue on my '95 Chevy, don't know if it would have the same effect on Fords. I don't have proof, so don't quote me, but I believe the RABS uses the brake lamp circuit to tell when the brakes are depressed and when it should be active. If the brake lamps are unplugged the RABS module won't function. Which also makes me realize, a faulty RABS module could be the culprit, sending voltage back through the brake lamp circuit when it isn't supposed to, hence them being dimly lit.
Old Dec 25, 2013 | 03:21 PM
Island Time
Interesting premise. I could see it happening. I'm not familiar with the RABS setup, but it would take a pretty specific type of failure to cause this. Still, electronics can, and do, fail in mysterious ways. Is there a simple plug from the brake light circuit to the RABS? If so, unplugging the RABS would be a very simple test. Brake light out with RABS unplugged? If so, RABS defective. If not, RABS not the cause.
Old Dec 26, 2013 | 07:12 AM
dixie460's Avatar
dixie460
Sorry. I misread that post, I thought you meant the RABS warning light was dimly lit.
I would check the multifunction switch and trailer wiring/connector if you have it. These are the only places I can think of where voltage might be crossing over onto the brake light circuits.
Other than that, check the brake light switch itself. Might have just failed and is passing enough leakage current to dimly light the bulbs.
93Fordguy
Mar 12, 2013 01:50 PM
regor
2009 - 2014 F150
Apr 21, 2012 12:55 PM
jwcorder
1983 - 2012 Ranger & B-Series
Apr 26, 2006 05:41 PM
sgtsaft
1997 - 2003 F150
Nov 3, 2005 11:46 AM
