Need to clear 35s
Old Dec 25, 2013 | 11:38 PM
Ken904's Avatar
Ken904
Need to clear 35s
I have a 1991 F150 XLT Lariat that is currently leveled with 33x12.5x15 BFG mud terrains. I know a lot of people have asked discussed this but I have yet to find out what I really need. My 33s rub a tad at a full turn with the level. What is the lowest body lift or suspension lift I would need to clear 35s?? I have a 3" Performance Accessories body lift kit that I got for free but haven't put on. I'm not sure if I want a body lift since all it does is lift the body(obviously), but suspension lifts are pricey. I like the look of my truck now but I want 35s. I want them to be as flush in the wheel well without rubbing, or trimming anything. You think a 2.5" suspension lift would do the trick? I know suspension lifts sag a little so maybe not. Maybe a 3" or 4". Idk, any and every suggestion will be considered and help me a lot.
Old Dec 26, 2013 | 02:23 AM
75Three90's Avatar
75Three90
I would go with your 3in body life. A body lift does the same as suspension.
Old Dec 26, 2013 | 06:08 AM
Jarryd's Avatar
Jarryd
You'll still rub your radius arms at full lock. No lift is going to change that.
Old Dec 26, 2013 | 06:09 AM
Bob Gervais's Avatar
Bob Gervais
Wrong.
A body lift puts undue stress on components that weren't designed for that stress. It also forces the use of longer body bolts, which are weaker than stock bolts. A body lift also doesn't increase wheel travel, some suspension lifts do.
To the OP: Your tires are going to rub on the radius arms, regardless of what type of lift you put on, if you're using stock wheels, or wheels with stock backspacing. The only way to change that is to use wheels with a different backspacing.
General rule of thumb is 4" lift for 33s, 6" lift for 35s.
Old Dec 26, 2013 | 06:55 AM
Jarryd's Avatar
Jarryd
While I agree with you that body lifts aren't the best, I don't think they're as bad as people make them out to be. I've seen hundreds of trucks running them locally and online. If I had a free one, you can bet your *** I'd be putting it in. I love the look of a 6" suspension with 3" body and 37s.
Old Dec 26, 2013 | 06:57 AM
Evan_P's Avatar
Evan_P
Hope your gears aren't stock. I had 35's (measured 35.5 inches tall BALD fully inflated) and with the stock 3.55 gearing my 5.8 felt gutless. In my opinion, it is NOT worth it. I hated everything about my 35's...
As for body lifts, I will never trust them. I had a friend in high school learn quickly why they suck. He got t-boned waiting to pull out of a parking lot. The cab shifted about 4" on the mounts. Every bolt was severely bent. If you can't afford a proper suspension lift, you cant afford to have a lifted truck. Simple as that.
Old Dec 26, 2013 | 07:17 AM
Jarryd's Avatar
Jarryd
If I had 35s, I'd step up to a minimum of 4.10s. 4.56 would probably be better.
Old Dec 26, 2013 | 07:45 AM
Evan_P's Avatar
Evan_P
4.56 minimum for me. I still find the 3.55's to be poor with my 33's. I lock out the overdrive until I go above 55. I have decided to not mess with gears in my truck. I will be getting a commuter car here within the next year and removing the truck from DD duty. She is just too thirsty to drive daily. Will be even worse when my commute jumps from less than 5 miles a day to 30+. After that I will likely pull the lift and the 33's in favor of stock height and tire size.
Old Dec 26, 2013 | 07:48 AM
Jarryd's Avatar
Jarryd
I went from 3.08 to 3.55 with my 33s so I can see how bad it really could be. I have a 300 so too much gear and it becomes useless. I still pull almost 20 mpg with my setup.
Old Dec 26, 2013 | 07:51 AM
Evan_P's Avatar
Evan_P
I'm pulling 10-12 with mixed driving. And that's with me taking it lightly and sticking to the slow lanes...
Old Dec 26, 2013 | 07:53 AM
Jarryd's Avatar
Jarryd
I could see that being a problem. You should just give me your lift kit so my 33s will fit better.
Old Dec 26, 2013 | 07:59 AM
Evan_P's Avatar
Evan_P
If you haven't lifted by the time I get around to tearing it out, I would be happy to send it your way...
Old Dec 26, 2013 | 08:03 AM
Jarryd's Avatar
Jarryd
It's likely that I won't by then. Being recently married and saving to buy a house means I got no mod money anymore.
*70F250*
Jun 3, 2007 08:42 AM
83Ford2x4
May 3, 2007 09:38 PM
Jeff621F150
Aftermarket Products
25
Mar 10, 2005 03:44 PM
x-star
2004 - 2008 F150
Feb 7, 2005 12:08 AM
