Poor cold weather performance
Old Dec 24, 2013 | 09:38 AM
Dan V's Avatar
Dan V
Originally Posted by Tugly
The EBPV should "allegedly" back off if the EBP sensor is working properly. This is a good catch.
As for the temperature, we know nothing so far.
You may recall, back in the *day* people were installing a resistor on the EOT circuit to fool the PCM into a lower EOT reading...supposed to be a power adder. Well I fell for that trap....and you would get a closing of the EBPV at what were really normal operating temps. I had it partially close pulling a 10k lb horse trailer up a grade...after driving for an hour before that. I got home and pulled that *mod* off.
Old Dec 24, 2013 | 10:27 AM
Pikachu's Avatar
Pikachu
Absolutely! I know this one from recording with AE under multiple seasons and conditions... not just in the driveway. The engine is depowered a little (to protect it when cold), the torque converter does not lock, to warm up the transmission faster, and the EBPV engages (sometime full-on, sometimes just a little) to aid with warming the engine faster. The truck is a total dog in icy temps, it was engineered that way to extend the ultimate life of the system.
Well, OK then. It seems like a bad idea safety-wise, since it's difficult to get over 45 mph when it's marginally cold, especially when you're getting on a 70 mph freeway . . .
Old Dec 24, 2013 | 11:00 AM
lartross's Avatar
lartross
I'm pretty sure that's just when the engine is cold. When it warms up [just a few minutes running down the road] mine runs normally...full power....zoom! You may have other issues...
Old Dec 24, 2013 | 11:29 AM
HD Rider's Avatar
HD Rider
Up here in Montana I filled with 17 gallons of #1 and topped off with #2 fuel. When the temps hit -23, she gelled to the point of quitting. Gelling does not always shut you down completely. I would try adding 16oz of 911 and waiting 15 minutes then try it. If it starts running better, you found the problem. Keep the rest in the bed (in case of spill) where it is handy if it ever happens again.
Old Dec 24, 2013 | 11:48 AM
JT250's Avatar
JT250
Exactly! Mine did it this year too. I could still drive. Although my fuel pressure gauge said 0. Some 911 and idling for 5 minutes and FP was back up to 65.
Your truck should not have a problem warming up. I would check the t-stat. If it is not gelled fuel.
Old Dec 24, 2013 | 12:32 PM
shadows4's Avatar
shadows4
Thanks for all the responses guys,
Here is what I have done today. Temps were about 18 degrees when I started the truck this morning. Truck started fine (was plugged in). Let it warm about 15 min then drove to store. Trip was about 6-7 miles mostly hwy speeds 60-65 mph. No change in way truck ran from yesterday.
Bought a bottle of 911 and added 8oz to 3/4 tank of fuel. Drove home and still no change.
Checked ICP connection and there was a thin film of oil around the plug. Is this normal? I mean you had to look really hard to see it.
Also before coming home I set the Scan guage to read EOT, IPR, ICP and Boost. EOT only got up to 152. IPR was running 30-35 on hwy. ICP was running 1800-2200 on hwy. Boost was only 1.0 and the highest I could get it to was 2.0 by flooring it.
In the past the truck has always started running right after it completely warmed up 180-190. But never got that high yesterday or today.
Not sure how to proceed from here but open to suggestions. Temps here are supposed to get up into the 40s here on Friday and Saturday. Think I will definitely change the thermostat.
Merry Christmas to all!!!
Old Dec 24, 2013 | 12:43 PM
Tugly's Avatar
Tugly
That's a sure sign of a closed EBPV... or a terrible boost/exhaust leak. Do you see soot anywhere under the hood or out the exhaust pipe? I wonder if your truck has been modified in any way.
Old Dec 24, 2013 | 12:50 PM
shadows4's Avatar
shadows4
I am positive the truck is stock. I bought it from the Dad of one of my buddys at work. Nice older gentleman. Had never worked the truck at all.
I did talk to my buddy yesterday, I was telling him about my troubles with the truck and he said that the thermostat was the original. Could the truck not warming up cause the lack of Boost?"
Is there a way to by-pass the EBPV?
Old Dec 24, 2013 | 01:28 PM
lartross's Avatar
lartross
Rich, wouldn't you have high boost with a closed epbv? I think it could be more than one issue...maybe bad thermostat and partially clogged fuel supply. The pick up foot commonly breaks off and/or the little screens in the pick up assembly get clogged And the stock quick connects leak air into the fuel stream....that's why these guys recommend the hutch/harpoon mod.
Old Dec 24, 2013 | 01:30 PM
lartross's Avatar
lartross
Ya know, as I think about it a closed ebpv would reduce exhaust gases, reducing boost.... wouldn't it?
Old Dec 24, 2013 | 01:49 PM
JT250's Avatar
JT250
T stat is most likely stuck open not allowing it to warm up. In turn the ebpv is staying closed to try to warm it up. Replace the t stat and see what happens. It is easy.
Old Dec 24, 2013 | 02:11 PM
Tugly's Avatar
Tugly
This is where my head was going.
EBPV restricts flow out the exhaust... not allowing the turbine to spool up. EBPV closed while driving faceplants the boost.
Motohead911
Aug 18, 2018 08:21 AM
Lex2002
13
Jan 27, 2012 06:34 PM
jeffdoerr
Apr 25, 2010 04:40 PM
aladin sane
Apr 14, 2007 09:48 PM
WJC
Feb 9, 2007 09:53 AM
