checking the oil
Old Jun 25, 2003 | 11:30 AM
85f-250-460's Avatar
85f-250-460
checking the oil
Nobody has been able to give me a straight anwser on this one.
do you check the oil before you start the motor or while it's running?
this is an 85 F-250 with a 460.
Old Jun 25, 2003 | 11:42 AM
laptopgeek's Avatar
laptopgeek
checking the oil
85f-250-460 ~
Always check the engine oil with the motor off.
Check tranny fluid with the engine running for at least 5 minutes as the Torque Convertor has fluid in it and you want to get an accurate measurement of ALL the fluid in the system (fluid will change when it gets warm).
Hoping that helps...
Old Jun 25, 2003 | 04:45 PM
jim henderson's Avatar
jim henderson
checking the oil
Like the other guy said... always engine off to check engine oil and engine on to check tranny fluid(Be sure to folow the owners manual procedure).
I prefer to check oil in the morning before I start up. If I have been driving, I like to let the engine sit for a few minutes, like when you stop for gas, wait until you are almost filled up before checking the oil.
Wipe the dip stick well and check the oil, then wipe and check again.
Good Luck,
Jim Henderson
Old Jun 26, 2003 | 06:40 AM
laptopgeek's Avatar
laptopgeek
checking the oil
Wha?!?...."..like the other guy said..."?...
I am... none other than the LaptopGeek, yours truly; at your service.
Old Jun 26, 2003 | 11:03 AM
jim henderson
checking the oil
Sorry bout that laptopgeek.
Just read an interesting article in Trailer Life mag, I think one of the summer issues, that talks about checking things on trucks. Jeez who but us would think checking oil is interesting?
Anyway, I guess there are some people out there who don't know the basics so they were trying to cover everything. Be sure you are on level ground. Be sure to push the dipstick in all the way. Don't let the dipstick touch any dirt, and wipe it if you do. Try to keep the level between the marks. A quarter inch or so high isn't killer, below can be killer.
Good Luck,
Jim Henderson
Old Jun 26, 2003 | 11:17 AM
laptopgeek's Avatar
laptopgeek
checking the oil
jim henderson ~
No prob....I was just joshin ya'''..it sure beats other things I've been called !!
Indeed, we all have to start somewhere...it seems only a few years ago (it's really been 30!!...) when I was at the GM Training Center in Altanta training to overhaul Pontiac 326 & 389 engines.... I had a leaking water pump and didn't even know how to fix it. A little earlier than that, my father was on the ground with me showing me how to change the oil on a '64 VW. Boy, THOSE were the days....
This is a good forum for us "elders" to now get down on the ground and help other needy people just like our fathers did us..... right?
whiskey runner
Feb 10, 2016 02:52 PM
Joshlovesjeeps
16
Aug 7, 2013 06:41 PM
85f-250-460
Sep 29, 2003 11:42 AM
stangboy_82
Exhaust Systems
Sep 3, 2003 10:24 AM
mark123456
May 7, 2002 01:18 AM
