Removing plastic step from bumper
Old Dec 22, 2013 | 02:45 PM
yellowboy's Avatar
yellowboy
I need to remove the plastic step from my 07 F150 bumper to paint it.
Do I just pull it up & off or do I need to get under it to do anything ? Thanks
Old Dec 23, 2013 | 05:52 PM
beersy50's Avatar
beersy50
It would be easiest to take the bumper right off the truck. On the under side there is a bunch of tabs that stick through the metal part of the bumper that lock the step pad down. You have to squeeze them with a pair or pliers (which is easiest off the truck so you can roll the bumper around on a stand). Its easiest to start on one side an work strait across the bumper. Keep upward tension on the step pad while you're releasing the locking tabs underneath.
Old Dec 23, 2013 | 06:42 PM
yellowboy's Avatar
yellowboy
Thanks much, I just have a corner of the bumper rusting so I'll just try and get it propped up on one side & see if I can get some rust preventer & paint under it.
sne43
Transit Connect
Sep 28, 2015 06:59 PM
uncle2abc
1983 - 2012 Ranger & B-Series
Jun 10, 2007 04:01 PM
Black Ford XLT
1978 - 1996 Big Bronco
Nov 22, 2003 08:09 PM
