1978 - 1996 Big Bronco
front bumper pad
Old Nov 22, 2003 | 07:49 PM
Black Ford XLT's Avatar
Black Ford XLT
front bumper pad
Any one ever remove there plastic front bumper pad, hows this done without doing any damage to it thanks TR (1992 XLT BRONCO)
Old Nov 22, 2003 | 07:55 PM
greystreak92's Avatar
greystreak92
Black Ford,
Yes, I have. It can be done fairly easily with a little patience and a good sized pair of lineman's pliers. Its easier to do with the bumper off the truck because some of the tabs are behind the bracketry. Otherwise, its just a matter of squeezing the mounting tabs from behind and pushing them through the steel until the lock portion is past the hole in the bumper. You can't pull them all out right away, just work your way across the back of the bumper until all of the tabs are free. Then it should just lift out of the holes. Good luck.
Old Nov 22, 2003 | 08:03 PM
Black Ford XLT
bumper pad
Thanks grey streak,i am going to remove the front pad and paint it,got a new ford bumper and the pad look terrible -dull ill try ya advice by squeezing the tabs TR
Old Nov 22, 2003 | 08:09 PM
greystreak92
If you look closely at the tabs you will see that they are not solid but rather hollowed out. They should compress enough to let you squeeze and push them through.
gmcbride
Oct 29, 2015 07:29 PM
Supercab
Jun 7, 2015 09:27 PM
Ford11
Sep 22, 2014 11:20 PM
Ford11
Sep 9, 2014 10:38 AM
ATX F250
6.4L Power Stroke Diesel
Apr 3, 2012 06:35 AM
