Cruise control problem
Old Dec 22, 2013 | 07:34 AM
mtr727's Avatar
mtr727
I searched the threads but haven't found this issue. I turn my cruise on and then attempt to set it , nothing happens , doesn't set, no light , nothing. I hit coast and the light comes on but still doesn't hold. Should the light come on when cruise is turned on or set? I checked the master cylinder switch and it's not wet. I also did the self diagnostic test and got nothing but the initial first light blink.
Old Dec 22, 2013 | 07:51 AM
mecdac's Avatar
mecdac
IIRC there are two switches on the brake pedal.
One for the brake lights and a second more sensitive switch that disengages the cruise control. If both are working correctly the switch that turns off CC will turn off CC even before signalling the brake lights.
Check these first, if the CC switch is always disengaging/turning off/overriding the CC it will not turn on.
Old Dec 22, 2013 | 08:02 AM
mtr727's Avatar
mtr727
How do I check the peddle switch? When should the light turn on? When set or just turned on?
Old Dec 22, 2013 | 08:21 AM
ExxWhy's Avatar
ExxWhy
Same symptoms I had except mine would blink when I tried to set it. It was a bad switch at the master cylinder on mine.
Old Dec 22, 2013 | 05:18 PM
projectSHO89's Avatar
projectSHO89
Go back and check the switch and fused harness for continuity.
bnorwood
Sep 5, 2019 01:24 PM
kirbinator13
Apr 26, 2019 01:03 AM
firebug
Feb 8, 2011 01:43 PM
xclint
1997 - 2003 F150
Jul 23, 2007 11:23 AM
4running
Feb 6, 2007 10:24 PM
