Sponsored by: Real Truck
HELPPPP. HEADLIGHTS
Old Dec 23, 2013 | 01:00 AM
Cristolize's Avatar
Cristolize
You might want to park that beast at night before your driving in the dark luck runs out.
Old Dec 23, 2013 | 05:20 AM
Yahiko's Avatar
Yahiko
How long have you had the HID kit? I had to replace a lamp do to it going out.
But then again I drive about 25~30K year and lights are on all the time.
But I had one other problem before that. The cheap fuse holder had melted.
So I would check the holder and the plugs to see if then have gotten loose.
One easy test is to power the ballast from the battery with a set of alligator clips.
Mind you that is test only. But like I said the light weight wiring and components
just are not meant for long term. You can pick up some better plugs at Autozone
and Pepboys for a decent price and just re-splice them in.
Sean
Old Dec 23, 2013 | 06:49 AM
02TB250's Avatar
02TB250
Have you tried plugging in your halogens to verify if it's the truck or the hid kit?
Sent from my Galaxy using IB AutoGroup
Old Dec 23, 2013 | 09:45 AM
automaticj5's Avatar
automaticj5
I have had the kit maybe 2 months. Truck is brand new less than 4000 miles...
I have not tried but good idea I definitely will!
Old Dec 23, 2013 | 10:13 AM
02TB250's Avatar
02TB250
My thoughts and by everyone's comments here we ask think it's the hid kit. But if you don't check you can't know for sure.
Old Dec 23, 2013 | 02:05 PM
kd0axs's Avatar
kd0axs
1. Remove HID kit.
2. Reinstall stock headlights.
3. Throw junk HID kit in the garbage.
4. Problem solved.
These HID kits are nothing but cheap junk. All they really do is blind oncoming traffic and they're illegal.
Sent from my HTC ONE using IB AutoGroup
Old Dec 24, 2013 | 06:49 PM
Delawhere?'s Avatar
Delawhere?
Originally Posted by kd0axs
1. Remove HID kit.
4. Problem solved.
WOW, couldn't have said it any better!!!
Old Dec 24, 2013 | 07:08 PM
2ndStroke's Avatar
2ndStroke
Stock light output sucks, so no, problem is not solved.
Old Dec 24, 2013 | 07:17 PM
automaticj5
That and I don't think everyone of us want the exact same looking truck. Customize and personalize.
Old Dec 24, 2013 | 07:38 PM
kd0axs's Avatar
kd0axs
Customizing is one thing, making yourself a hazard to everyone else on the road is another. Those HID kits look cool, unless you're in oncoming traffic. Then you're being blinded by them. HID bulbs emit light differently than a halogen bulb, so it's impossible to properly aim your headlights when you have an HID kit in a housing designed for halogen bulbs. That's why they're illegal. HIDs need to be in a projector housing designed for them in order to work properly. Look at a vehicle with an HID kit next to one with OEM HID headlights. The difference is obvious.
Old Dec 24, 2013 | 07:49 PM
automaticj5
Customizing is one thing, making yourself a hazard to everyone else on the road is another. Those HID kits look cool, unless you're in oncoming traffic. Then you're being blinded by them. HID bulbs emit light differently than a halogen bulb, so it's impossible to properly aim your headlights when you have an HID kit in a housing designed for halogen bulbs. That's why they're illegal. HIDs need to be in a projector housing designed for them in order to work properly. Look at a vehicle with an HID kit next to one with OEM HID headlights. The difference is obvious. Sent from my HTC ONE using IB AutoGroup
Fair enough. I'm working on getting the projector swap done. Just not sure which kit and from where
Old Dec 24, 2013 | 07:50 PM
automaticj5
Although I will say I've never had anyone flash lights at me...
Old Dec 24, 2013 | 09:28 PM
  #28
2ndStroke's Avatar
2ndStroke
I had a couple people flash me before I aimed them, haven't since. These housing are well designed, plus aiming does alot.
Old Dec 25, 2013 | 12:13 AM
  #29
Yahiko's Avatar
Yahiko
You don't need to have HID's to be a blinding light. There way too many cars out
on the roads that the owners don't have a clue on how to change a lamp and not
screw up the aiming. Then there the ID 10 T's that run around with the high beams
on. Then there is the ones that think that a higher K # means brighter. The human
eye does not respond as well in the blue range as it does in the yellow. So the guy
with the 35 Watt 4300K can see better than the guy with the 55 Watt 10K lamps.
The blue tends to scatter faster also. It's that scattered light that is the problem.
The newer Fords when aimed right they have a very sharp cutoff.
As far as I am concerned get rid of the projectors that are mis-aimed.
And when coming onto a bright lighted vehicle don't look right at it. look
down to the right at the fog line. That way you don't get so wiped out.
Sean
Old Dec 28, 2013 | 08:42 PM
  #30
automaticj5
So what if the problem ends up being the relay??! The company is sending me new ballasts right now. Is there anywhere I can just go get a relay?
maybelle'84
Jun 21, 2019 03:46 PM
cuda66
Dec 21, 2013 10:16 AM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
84tealbeast
May 31, 2006 11:34 AM
