help with part numbers
Old Dec 21, 2013 | 11:33 AM
djousma's Avatar
djousma
All,
After my primary radiator replacement was completed, it looks like the mechanic might have gotten a little lazy, but several plastic rivet's, clamps are broken. Yea I should go back to the dealer and have them make it right, but honestly, my time is worth more than that. I was looking for these parts at an online Ford parts dealer, but cannot find these in the parts diagram. Any help would be appreciated. The parts cannot be more than a few bucks.
Notice the missing rivets to the right holding the seal to the top of the radiator. Several of the others are loose/broken.
On this one, the clamp that holds the hose to the radiator is broken.
As a side note, the primary cooling reservoir was pretty low too, I'm assuming the mechanic didn't run the truck long enough to purge all the air from the system, as I don't notice any leaks. I already had some specialty orange and distilled at home, so I refilled to the max cold line and will watch it.
Thanks in advance, Dave
Old Dec 21, 2013 | 11:36 PM
marchare011's Avatar
marchare011
While I understand why you want to finish fixing it yourself, I would see if the dealer would provide the parts or at least the part numbers. If he doesn't know you are dissatisfied, he won't ever improve the level of service. Just a thought.
Old Dec 22, 2013 | 04:42 AM
djousma's Avatar
djousma
Thanks Ron. My service writer does email. I will probably just email him the same photos.
Old Dec 22, 2013 | 05:39 AM
Hdslider's Avatar
Hdslider
Ron. Oh so true. show service manager. Then let him handle the lazy tech that has no pride in his work.
Old Dec 22, 2013 | 01:31 PM
Dpica15's Avatar
Dpica15
Parts number for the seal rivets is W706350 S3000
For the coolant hose i can't find a number, might be part of hose assy.
Old Dec 22, 2013 | 08:22 PM
djousma's Avatar
djousma
Thanks, but i just did a google search on that part number, and those are not what is on the truck. The ones on my truck just push in with some splines to hold it in. Not a two piece deal like these.
Old Dec 23, 2013 | 05:16 AM
senix's Avatar
senix
He was lazy. a lot of times they cut the underside to get them off but not so close. They are rather long. If you cut them but leave some on it then they will still work.
I'd get them to give you a handful and then go put them on or have them do it on the spot..better yet!.
Old Dec 23, 2013 | 07:09 AM
djousma's Avatar
djousma
Yea, thats what I am thinking. I've been watching the coolant level in the degas bottle too. Was close to empty when I popped the hood on Saturday morning. Added about a 1 1/2 quarts of 50/50 specialty orange and distilled right to the top of the cold full line. Checked again Sunday morning, down a little, added to the top of the cold full line. Checked again this morning, down a little again. In total about a 1/2 gallon added.
I'm wondering how long it takes to purge the air out of the system? No leaks showing on the ground, and each time I am adding less.
Old Dec 23, 2013 | 09:45 AM
djousma's Avatar
djousma
Just heard from the service writer. "Tech is in the parts department, ordering these rivets and clamps".
Still monitoring the coolant level.
Twonky
Sep 22, 2017 07:52 PM
Bazillions
6.7L Power Stroke Diesel
Nov 2, 2015 06:23 PM
Shaneb75
Jul 21, 2015 06:32 PM
neilc88
Dec 29, 2011 08:21 AM
Munkey
Sep 23, 2004 04:41 PM
