Stage 1 injectors
Old Dec 24, 2013 | 10:02 PM
  #31
dougbrown's Avatar
dougbrown
Are u saying a d66 is to big or to small? If I'm right they waste gate turbos in big trucks to spool them.
Old Dec 24, 2013 | 10:13 PM
  #32
fordpride's Avatar
fordpride
The d66 is just a stock turbo with a different compressor wheel, housing, backing plate and 360* oiling bearing.
Old Dec 24, 2013 | 10:16 PM
  #33
fordpride's Avatar
fordpride
Technical Articles | How Does A Wastegate Work | Turbosmart USA
  #34
dougbrown's Avatar
dougbrown
I know what a d66 is and how waste gates work. I just don't see the d66 being to small for them. I know guys running 238/100 on stock sd turbos with a ww2 wheel and no problem.
Old Dec 24, 2013 | 10:49 PM
  #35
fordpride's Avatar
fordpride
The stock turbo shaft becomes the issue after around 30psi
Old Dec 24, 2013 | 11:23 PM
  #36
strokin'_tatsch's Avatar
strokin'_tatsch
The 360* thrust helps with the added back pressure at high boost pressures if the D66 has one. I haven't seen inside a D66, but I'm sure they do something with it since people run decent pressure with them. The D66 should be fine around 35psi or so, but I'm not sure what back pressure is going to look like. EGTs could become a problem. Any which way you look at it, the D66 has a stock exhaust side and exhaust will not be able to escape any faster than a stock turbo.
That is where the wastegate comes in for the SD guys running hybrids with their D66. We have a larger turbine housing than they do, but with my stage 2s and a stock turbo a couple years ago I was seeing close to 2:1 drive to boost ratios. The turbo was perfectly fine with that for about 100k miles and its still in great shape after I removed it, so the D66 should survive, but I bet EGTs will still get kinda hot.
Royson12
83
Oct 11, 2014 08:53 AM
dwnshift79
Apr 29, 2012 02:59 PM
seanlleiker
Jan 25, 2011 12:39 AM
wmiller
Sep 5, 2008 10:22 PM
FarmboyAC
Sep 5, 2005 09:50 PM
