Is there a write up on replacment of rear window motor?
yea check utube or over at fsb also.
if you drop the gate, open the rear panel and trigger the latch mechanism on the sides as if the tailgate was closed you can then use the window switch to roll up the window if you will. make sure you have a way to support the window on something. this will give you access to everything.
