Leaking Gas
Old May 24, 2014 | 01:17 AM
kishkumen's Avatar
kishkumen
Leaking Gas
Well I bought a 1979 F-250 Custom a couple months ago, and I've finally gotten time to mess with it. Honestly, I don't know much about engines and such..but that's why I bought the truck. I want to learn.
I can get the truck to start just fine. It runs well, except that there is a small leak of gas coming from under the carburetor. I'm assuming the rubber gasket is bad, and it just needs to be replaced. I don't know if that's the real problem or where to start. Any help appreciated. Thanks!
Old May 24, 2014 | 03:09 AM
rockittsled's Avatar
rockittsled
Can you use a small inspection mirror to identify where the leak is coming from? Through a gasket under the carb, from the carb, back, side or front of carb, dripping from a part attached to carb?
Old May 24, 2014 | 08:42 AM
tbear853's Avatar
tbear853
Is it a 351m or 400 or 300 I-6 or 460?
Is it a stock Motorcraft 2bbl or 4bbl carb, aftermarket Holley 4bbl, or what?
When / under what circumstances are you seeing this leak?
Holleys and the MC carbsl use diaphragm accelerator pumps that can leak, power valves that can leak .... and Holleys often leak between carb main body or metering blocks and float bowls, and there's fuel line fittings that can leak. If floats are high, Holleys can also leak at float sight level plugs.
A picture would help.
Old May 25, 2014 | 12:28 AM
kishkumen's Avatar
kishkumen
It is a 351M. It has a Holley 4 barrel. Not sure what size it is they drilled the holes bigger according to the guy I bought it from.
When the truck runs for a few minutes it starts to leak. It leaks just in the front right under the carb.
So if Holleys normally leak do I need to do anything about it or just leave it be?
I will put a picture up.
Old May 25, 2014 | 06:54 AM
redroad's Avatar
redroad
Any fuel on top of a hot intake is not good it will catch fire at some point and start melting shxt at the very least .. The heat will warp the mating surfaces in the carb and it will be junk .. Rebuild the carb .. A kit is about $30-$50 depending on the carb and use only genuine holley parts or you'll have the same problem you got now
Wbruiser2
Dec 19, 2013 07:35 AM
JCastellaw
1966 - 1977 Early Broncos
Jun 18, 2008 11:20 AM
FitchBanjos
13
Mar 5, 2008 06:05 PM
kevinken
May 3, 2003 09:04 PM
cat house mouse
Mar 11, 2002 06:33 PM
