2wd to 4wd
2wd to 4wd
I have the inline 6 motor and it's has a transfer case and all that and I'm buying another motor but it's connected to a 2wd trans will it bolt up fine to mine?? I know it's a stupid question but gotta ask just to make sure
Not really a stupid question. The engine will still bolt to your current trans, as the bellhousing pattern is the same on all 300's. However, if the trans is not the exact same model, you *may* need to use your current flexplate/flywheel and starter.
darkpurp1e
Feb 7, 2012 01:22 PM
Pickupmanx2
May 12, 2009 11:59 PM
muscletruck7379
Mar 4, 2007 07:47 AM
