6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
fuel pump
Old Dec 17, 2013 | 06:33 AM
emayes2000's Avatar
emayes2000
Exclamation fuel pump
Any one had to replace fuel pumps in the 6.4. If so what was the way to go about replacement?
Old Dec 17, 2013 | 03:47 PM
Mudslinger72315's Avatar
Mudslinger72315
From my understanding, there are two pumps. Essentially a low pressure and a high pressure. The HPFP is a cab off replacement.
Old Dec 18, 2013 | 10:04 PM
tgreening's Avatar
tgreening
If it's the low pressure, drain savings account, pay bill.
If it's the high pressure, drain savings account, go to bank and get loan, pay bill. :/
That's only half a joke. The HPFP is an expensive fix pretty much not matter what. If you get lucky you'll get to it before it actually grenades. That's merely expensive. If it grenades internally it tends to take out just about everything down stream and that gets stupid expensive.
Old Dec 24, 2013 | 01:11 AM
KPBJJ's Avatar
KPBJJ
People are doing HPFP cab on. Make sure you get the updated HPFP cover gasket.
Old Dec 25, 2013 | 08:32 PM
emayes2000's Avatar
emayes2000
Thanks for the information.Is it a common problem?
Old Dec 25, 2013 | 08:46 PM
KPBJJ's Avatar
KPBJJ
I guess there are a couple problems people have with the HPFP that I'm aware of. The one that I was referring to is with the HPFP cover gasket the old wires on the driver side plug aren't protected well and they get chaffed from rubbing against the cover and eventually ground out. If you google the cover gasket you can see the difference between the old and the updated versions. The new one has a plastic sleeve covering the wiring going to the plug. Just changed mine.
Old Dec 25, 2013 | 08:48 PM
KPBJJ's Avatar
KPBJJ
do you think you have a issue with yours? Symptoms?
anthonym92
May 31, 2017 05:38 PM
armstrongfordtrucks
Aug 8, 2010 12:46 PM
G & L
Feb 10, 2008 09:47 AM
Maxium4x4
Dec 14, 2007 09:48 PM
