6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What is this??
Old Dec 24, 2013 | 01:36 PM
StanleyZ's Avatar
StanleyZ
What is this??
Anybody want to tell me what this is? I've been under this hood 100s of times and never noticed it before. Looks like it should have a hose attached but I can't find a picture of it with a hose on.
Old Dec 24, 2013 | 02:13 PM
UGA33's Avatar
UGA33
That's your egr valve.
Old Dec 24, 2013 | 02:25 PM
Booma's Avatar
Booma
I agree, it's your EGR valve. On my 2010 the part number has changed and I do not have the tube installed that could accept a hose and on the other side there isn't even a place that a tube could go, it's blocked off in the casting. No hoses are used, maybe it's an older design that actually used those auxiliiary ports. Shop manual volume 2 page 303-08-11 shows the EGR valve installation, again no hoses.
Old Dec 24, 2013 | 02:33 PM
GHeTTo JOe's Avatar
GHeTTo JOe
probably a good thing they left the EGR valve in the truck, my understanding is that it is the "wastegate" for the 6.4 ?
Old Dec 24, 2013 | 02:34 PM
UGA33's Avatar
UGA33
Early versions were cooled with coolant.
Old Dec 24, 2013 | 03:10 PM
StanleyZ's Avatar
StanleyZ
I was asking specifically about the little tube protuding from the EGR valve. As best I can tell it has always been bare like it is now. i just wondered if something was missing.
Old Dec 24, 2013 | 03:30 PM
Booma's Avatar
Booma
In the shop maintenance manual there is nothing connected to the little tube you reference.
Old Dec 24, 2013 | 03:40 PM
sv250's Avatar
sv250
I have a 2010 and dont have that tube.
Old Dec 24, 2013 | 03:56 PM
senix's Avatar
senix
since you are deleted they removed the hose to the valve. Just plug it with a piece of hose or something.
Remember the venturi T.
Old Dec 24, 2013 | 10:10 PM
StanleyZ's Avatar
StanleyZ
Sure I do, but I still have the Tee and two hoses going to it. However, I found a picture with the hose attached to this tube. And when i look at both pictures it looks like the other end is on the Tee. So I have to look and see what's going into the Tee now.
Old Dec 24, 2013 | 10:14 PM
GSchretter's Avatar
GSchretter
You are good to go long as you have a tube running from your vertical EGR on the top running to the degass bottle.
EGR has no function as a blow off valve.
Old Dec 25, 2013 | 08:21 PM
StanleyZ's Avatar
StanleyZ
Yep. you called it, hose from top of vert EGR cooler to degas tee. But in the old pic there is another hose, from top of vert EGR cooler to something I can't see in the picture. I'm assuming that if I wish to go back stock I'll need to return those hoses. Is that correct?
Old Dec 25, 2013 | 08:33 PM
GSchretter's Avatar
GSchretter
Yes, but even in stock if you disabled your EGR (EGR cmd = 0) and you use block off plates you will not as then your coolers will only be mini coolers for coolant and no exhaust will be passing onto the intake.
Ps.
Nice engine bay!
Old Dec 25, 2013 | 09:34 PM
StanleyZ's Avatar
StanleyZ
Ps.
Nice engine bay!
Thanks, in stock if the EGr was disabled it wpould throw codes right? Besides I don't think my tuner can disable the EGR without deleting.
1OldFordMan
Feb 1, 2012 11:54 AM
octaneforce
Feb 28, 2011 04:45 PM
Blue Rebel
Sep 19, 2010 07:05 PM
1965HHORunner
Jun 10, 2010 10:26 AM
timmosazz
Jan 21, 2007 09:27 PM
