Bearing
Old Dec 15, 2013 | 11:12 PM
Boodrow379's Avatar
Boodrow379
Bearing
My front drivers side wheel bearing went out on my 1973 f250 highboy. It is a dana 44, I took off the hub, then the nut spacer and other nut which was a major pain in the *** and now I am to only the bearing. I have tried prying it off, I chained it to another truck and tried to pull it off, nothing is working. I am at a loss I rebuilt this whole truck and I hate to see it die just because of a wheel bearing it is my daily driver, does anyone have any ideas on how to get it off? I cant believe I am having so much trouble with something so simple. Ill post a picture of what I have tomorrow.
Old Dec 16, 2013 | 01:43 AM
Ordnance's Avatar
Ordnance
Try Alternating heating and cooling it? I've had a few things stuck on in my day that required a torch. You could also try getting a BIG pipe wrench, tightening it down super tight and whacking the end with a hammer to break it loose.
As an extreme, try going to an industrial supply store and get an extra large nut splitter.
Old Dec 16, 2013 | 03:25 AM
f150kindaguy's Avatar
f150kindaguy
I had mine pressed out by a professional grade press.
ps. total cost 0.00
A fabrication/auto shop will have the hydraulics to do it.
Old Dec 16, 2013 | 05:57 AM
monsterbaby's Avatar
monsterbaby
IF your sure that there isn't another nut still on there (I did actually see someone put 3 on a truck once) and the problem is you can't get the hub off the spindle, try putting a log chain on one of the lug studs with a lug nut. Then don't pull it with another truck, that never works. Rather whip the chain like well whip.
Old Dec 16, 2013 | 08:19 AM
Boodrow379's Avatar
Boodrow379
Lol ok, I'll try that next time and heat and cool it at the same time. Thanks everyone
Old Dec 16, 2013 | 12:01 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Go buy a 4 point hub socket from most standard auto supply stores for the PITA outer and inner nut. You will like having it come reassembly time.
Sound like the inner bearing is seized to the axle shaft. Use a cut off wheel to cut the bearing cage off and then CAREFULLY cut a diagonal cut across the inner piece and once you cut almost all the way thru it, use a chisel to break the last bit.
Might as well insp the outer hub bearing races and replace as needed since you are right in there. I am sure the inner race is shot, and do not forget to replace the inner axle seal.
meaning the tap in metal/rubber one that goes on after the inner bearing is installed.
Old Dec 16, 2013 | 01:23 PM
f150kindaguy
if its rusted/fused together i would say buy a new one..
i can't imagine it being more than 60$-80$
usually i like to recycle as much parts as i can.. even for safety
by the time you yank that guy off i can only think of the metal wear and tear.. gl
Old Dec 30, 2013 | 11:29 PM
Boodrow379's Avatar
Boodrow379
Thanks everyone fir all the replys, I tried most of them and what I ended up having to do is I not intentionally made a hole in the outer race, knocked all the roller out, pulled the hub assymbly off, then cut the inner race off the spindle with a grinder. The inner and outer race were both really welded on. But I replaced the inner and outer bearings and seals, now i just have to not be lazy and do the same to the other side lol. Thanks everyone
Old Dec 31, 2013 | 09:31 PM
VocaTexas's Avatar
VocaTexas
Front wheel bearings are probably one of the most neglected maintenance items there is. That's why they are one of the first things I check when I get a 'new' pick-up. I learned the hard way, too.
drumfield
Jan 25, 2019 04:56 PM
1993 ford
Aug 15, 2017 09:35 PM
davidsnook1981
31
Dec 23, 2011 05:23 AM
99f350sd
Mar 3, 2006 04:05 PM
bigblockfan
Jul 13, 2002 05:43 AM
