scan guage
ScanGauge II Codes
Thnx npccpartsman
It will NOT do fuel pressure, EGT's or engine oil pressure since there aren't any PCM sensors to monitor those functions. Here's my short list:
Scan gauge inputs: ScanGauge II XGauge codes - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum
FORD 6.0 L Diesel:
GAUGE TXD RXF RXD MTH NAME
FL 07E02216C1 0462451606C1 3010 000101480000 Fuel Level
VRF 07E0221155 046205110655 3010 006433330000 VREF (CALIBRATION VOLTAGE INPUT)
BAT 07E0221172 046205110672 3008 000100010000 BATTERY VOLTAGE
ECT 07E0221139 046205110639 3008 000200010000 ECT Degrees F
EOT 07E0221310 046245130610 3010 00090005F05F EOT Degrees F
TFT 07E1221674 046205160674 3010 000100080000 TFT Degrees F
IAT1 07E0221123 046205110623 3010 000100010000 IAT1 Degrees F
IAT2 07E02216A8 0462051606A8 3010 000100010000 IAT2 DEGREES F
ICP 07E0221446 046205140646 3010 003900640000 ICP PSI
ICV 07E02216AD 0462451606AD 3010 004827100000 ICP voltage
IPR DC% 07E0221434 046285140634 3008 0DCA03E8000A IPR %
INJPW 07E0221410 046245140610 3010 044C04E2FFF1 FPW Microseconds (table)
INJPW 07E0221410 046205140610 3010 000800010000 FPW Microseconds (modified)
ITM 07E02209CC 0426850906CC 3010 000A00400000 INJECTOR TIMING BTDC (DEGREES)
MFD 07E0221412 046245140612 3010 006400100000 MFDES Mg per Stroke
MFD 07E0221412 046245140612 3010 000100100000 MFDES (ALT)
VFDES 07E0221411 046245140611 3010 006400100000 VFD Cubic mm
FMP 07E02209D0 0462450906D0 3010 006401000000 FICM Main Power (Volts 47-48)
FVP 07E02209CE 0462450906CE 3010 006401000000 FICM VEHICLE POWER (SHOULD BE 12 VOLTS)
FLP 07E02209EF 0462450906CF 3010 006401000000 FICM LOGIC POWER (SHOULD BE 12 VOLTS)
FSN 07E02209CD 0462050906CD 3601 000100010000 FICM-sync 0=NO, 1=Yes
SYC 07E02209CD 0462050906CD 3000 000100010000 SYC CAM/CRANK POSITION SENSOR SYNC (1= IN SYNC)
SYC 07E02209CD 0462050906CD 3001 000100010000 SYC ALTERNATE
SYC 07E02209CD 0462050906CD 3701 000100010000 SYC ALTERNATE
FSS 07E022099F 04620509069F 3010 000100040000 FAN SPEED SENSOR
FDC 07E022091F 04624509061F 3010 013103E80000 FAN SPEED DUTY CYCLE
Baro 07E0221127 046285110627 3008 003100500000 BAR Inches of Mercury
EBP 07E0221445 046285140645 3010 001D00500000 EBP PSI
EBP 07E0221445 046285140645 3010 001D0050FFFB EBP (-0.5 PSI)
BST 07E0221440 046285140640 3010 01220320???? PSI/BST MAP Modified signal PLUG IN VALUE FROM TABLE FROM YOUR MAP
MAP 07E0221440 046285140640 3010 012203200000 MAP EXTENDED RANGE
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Quote
Here are the Xgauges I now have entered in my Scangauge II. The ScII reads x gauges from #24 to #0 So I entered them alphabetically by name for easy access. I normally run:
FMP, ECT,EOT, VOLTS. While towing I will switch to add Fan speed and TFT.
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: BST
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74 (I USE THE "FF71" FOR MY AREA, IT WORKS GREAT)
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
VREF= Voltage reference
TXD: 07E0221155
RXF: 046205110655
RXD: 3010
MTH: 000133330000
NAM: CVI
EBP
Exhaust Back Pressure
07E0221445
046285140645
3010
001D00500000
EBP
Engine Oil Temp.
07E0221310
046245130610
3010
00090005F05F
EOT
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48) (this does work! )
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
Gear
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100010000
NAM: GER
IA2 Sensor
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Inj. Control Press.
07E0221446
046205140646
3010
003900640000
ICP
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
07E0221434
046285140634
3008
0DCA03E8000A
IPR %
Mass Fuel Desired (in milligrams perstroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3701
MTH: 000100010000
NAM: SYC
Trans. Fluid Temp.
07E1221674
046205160674
3010
000100080000
TFT
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
Quote
These are from James DeLong at Scangauge. (Well, thats a lot of gauges. )
Yea, MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
Manifold Absolute Pressure
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Quote:
Originally Posted by DieselStroke
Go ahead and give me any codes that you may have for the injectors, i am always happy to try out new things. Please let me know if you have any other gauges for our trucks that may be potentially useful, we are happy to try anything you throw at us.
Thanks,
Patrick
Here's what I have for injectors
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
Fuel Injector Pulse Width (microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Fuel Injector #1 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3001
MTH: 000100010000
NAM: FI1
Fuel Injector #2 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3101
MTH: 000100010000
NAM: FI2
Fuel Injector #3 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3201
MTH: 000100010000
NAM: FI3
Fuel Injector #4 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3301
MTH: 000100010000
NAM: FI4
Fuel Injector #5 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3401
MTH: 000100010000
NAM: FI5
Fuel Injector #6 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3501
MTH: 000100010000
NAM: FI6
Fuel Injector #7 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3601
MTH: 000100010000
NAM: FI7
Fuel Injector #8 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3701
MTH: 000100010000
NAM: FI8
He is working on an injector misfire count right now that should tell us if there is an injector that is performing worse than the average!
Here's what I have for misfire counts.
Cylinder #1 cumulative misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 cumulative misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 cumulative misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 cumulative misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 cumulative misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 cumulative misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 cumulative misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 cumulative misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
-------------—-•________-
x1^^^^ Agree.
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Originally Posted by amdriven2liv
Here is a MAF code from Scangauge II to try.
Mass Air Flow (Gram/S)
TXD: 07E0221671
RXF: 046245160671
RXD: 3010
MTH: 000100010000
NAM: MAF
BLADE35
2003 Ford F-350
Here is the FPW X-Code I have
Fuel Pulse Width=
FPW Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
You guys try this code and see what you think^^^^^^^^^^^^^^^^^^^^^^
Im not shure if this is the one I have programmed into the SGII or Not I will verify the Code in the AM
But am curious to see what you Guys Get
AT KOEO FPW should be 0
and at KOER should be a Value hold on a sec
FUELPW 0 990 680 0 - 50000 (μ seconds) Fuel Pulse Width
and MAF should be
I didnt see one for Grams IDK in the operating Values we gotr from Cheezit
I saw one for MAF Volts I was hopen that he would give us the MAF Volt one and maybe he did will enter it in 2 morro and see what he gave us
Benny
https://www.ford-trucks.com/forums/a...8&d=1337911266
Many of these are duplicated a couple of times. If one doesn't work it may be typed incorrectly. Compare to a different entry elsewhere on the list. (Sorry)
I don't think its the PCM
Most common is HPO leaking and being able to build pressure
IDK of anyone that got the Injector ones to work
Always a Long ccrank or just when Hot???
Watch these
ICP
ICPV
IPR%
FPW
ICP will want to hit 500+ psi before the FICM and stuff will turn on and Give it a FPW
Post ICPV at KOEO (Key On Engine Off) this will Determine a couple things like if it wired right
Post ICP and IPR% at Crank & Idle & 2500RPM
ALso watch your RPM it Must get into the 150rpm Range to Start since the HPOP is Gear driven
I thought the ICP sensors was same and it was the IPR that was Different per 03 vs 05+
With all these Gauges theres Ford Specs for KOEO--idle--2500rpm
Take the readings at those with A/C Off in Park
here you go use this PDF
SENSOR OPERATING VALUES PDF
https://www.ford-trucks.com/forums/a...1&d=1364848489
