electrical help f100 1971
Old Dec 15, 2013 | 10:50 AM
trickpats's Avatar
trickpats
hey so as im driving down the road my headlights and dash lights will dim and get brighter. i dont know what it is. any help is appreciated
Old Dec 15, 2013 | 11:24 AM
Gembone's Avatar
Gembone
is it a pulsing or and immediate change? if pulsing look towards your alt and voltage regulator, and possibly the connector on the headlight switch. if immediate then look to the headlight switch and or connector.
Old Dec 15, 2013 | 11:27 AM
trickpats's Avatar
trickpats
what do you mean by immediate change?
Old Dec 15, 2013 | 11:29 AM
Gembone's Avatar
Gembone
flicker, hit a bump it instantly is brighter or dimmer.
a pulse would be slowly changing from one into the other.
Old Dec 15, 2013 | 11:36 AM
trickpats's Avatar
trickpats
its a pulsing i can be sitting in the driveway and it will flicker on the garage door
Old Dec 15, 2013 | 11:45 AM
Gembone's Avatar
Gembone
check the plugs and connections for the voltage regulator and headlight switch, possibly even the floor dimmer switch.
Could be a corroded or loose connection. Maybe someone else will chime in with more suggestions.
Have you put a meter on it while running to see if you have steady amps and voltage?
Old Dec 15, 2013 | 12:27 PM
HIO Silver's Avatar
HIO Silver
Check the grounds... extra grounds are also a good idea.
Check all connections but the usual suspect of pulsating headlights is the voltage regulator.
A recommended upgrade is to relieve the ignition switch of the headlights and use relays to directly source voltage from the battery. The headlight "on" signal is then just used to trigger the relays and the result is more efficient voltage and therefore, brighter lighting.
Old Dec 15, 2013 | 04:39 PM
MeanGreen460's Avatar
MeanGreen460
I'd check your Alt belt first for tightness .a loose slipping belt could be causing your problem then check alt and voltage regulator if belt is tight not slipping
Old Dec 15, 2013 | 07:44 PM
kenny nunez's Avatar
kenny nunez
headlights
X2 HIO grounds and relays.
Meanstreak97
Electrical Systems/Wiring
Aug 22, 2014 08:18 PM
John Aary
Apr 19, 2013 07:39 AM
69bluebeauty
13
Dec 14, 2012 01:05 PM
ddlyarmbar
15
Jun 22, 2005 11:54 PM
jd4430
Jan 14, 2005 11:42 AM
