Sponsored by: Auxito
4x4 problems
Old Dec 15, 2013 | 01:39 AM
sk8erdude423's Avatar
sk8erdude423
4x4 problems
when I turn the switch to put my truck in 4 wheel drive I can hear it clicking inside the dash but the light for 4x4 does not come on and the front wheels don't lock in. Any ideas where to start
Old Dec 15, 2013 | 06:30 AM
enriched&beyound's Avatar
enriched&beyound
usually....one needs to check the front axle for a vacuum leak.
If that is all good, no vacuum leaks...then the actuator (what the vacuum line attaches to), might be seize...they tend to do that from lack of use.
It can be removed and with your favorite spray lube (wd40, kroil, blaster...etc) & some simple tools you might be able to get this to free up.
Old Dec 15, 2013 | 09:48 PM
sk8erdude423
It will not lock in at the transfer case
Old Dec 16, 2013 | 05:59 AM
enriched&beyound
then T-case is the issue...might be a simple electrical connection or something far greater like stripped gear....hopefully your T-case does not have water in it and is froze. does it even have oil in it?
Old Dec 17, 2013 | 12:43 PM
sk8erdude423
Yeah I can turn it manually but I lose power from the switch to the motor on the t-case
Old Dec 17, 2013 | 04:44 PM
enriched&beyound
have you check the relay or fuses for the T case?
more info you may find useful
Rebuild Kit BW4406 Transfer Case and Parts plus Illustration drawing and parts list! - Drivetrain.com
or
4x4 Woes - F150online Forums
Old Dec 17, 2013 | 05:07 PM
sk8erdude423
Is there a inline fuse anywhere
Old Dec 19, 2013 | 05:49 AM
enriched&beyound
doubtful if any "inline fuses"....but
so you checked the #3 & #23 fuses and the larger "maxi fuse #104...yes?
So...also...No vacuum leaks to the actuator and the plunger rod under the actuator moves freely.
Also...the T-case has correct oil and level in it.
^^^ all true^^^?
have you had a front windshield replaced or is leaking?
Is there anything else strange going on inside the cab...lights flashing or turning on or shutting off? The Heater and A/C is placing air where it is suppose too?? also check for vacuum leak...behind the battery.
you probably need some assistance checking the T-case motor....check the amp draw as the switch gets rotated to each position. maybe the T-case motor is weak??
or maybe the switch on the dash is not providing power to the T-case motor...hopefully a simple switch is all or a bad wire....but....
there is a "GEM" module inside the dash that controls the tranny and T-case and other major fuctions, that can short out...usually if that happens you get all kinds of strange electrical activity...I think it ties into the anti theft...so it maybe a dealer only replacement?...so that they can tell all the electronics that everything is OK after the replacement.
more info on GEM >>>https://www.ford-trucks.com/forums/1...ogramming.html
Old Dec 19, 2013 | 09:42 AM
bryanwheat's Avatar
bryanwheat
If if works I 4 low but not 4 hi than it is the gem module or selector switch. 4 hi and 4 low use the same wires and relays to move the encoder motor. What you are hearing is the relay for the synchronization clutch inside the transfer case. Since the gem is sending a signal to the clutch relay but not shifting the case I would go with the gem module having an issue.
Old Dec 24, 2013 | 12:32 AM
sk8erdude423
It ended up being a broken wire on the gem module and the shorted out the switch in the dash too
Old Dec 24, 2013 | 07:25 AM
enriched&beyound
so you had the "AHH haa" moment
glad you got it fixed
Merry CHRIST-mas
Kamstutz
40
Feb 10, 2013 10:07 AM
78 Ranger
Electrical Systems/Wiring
Oct 18, 2011 06:22 PM
superduty4x4
Feb 10, 2010 02:48 PM
Chris 97 F150
1997 - 2003 F150
Jan 15, 2007 12:29 AM
jvraz
1997 - 2003 F150
32
Feb 3, 2006 08:57 AM
