Modular V10 (6.8l)
Engine randomly missing, no codes. HELP!
Old Dec 14, 2013 | 02:30 PM
pumpcaptain's Avatar
pumpcaptain
Is there a quick indicator if a plug coil is bad? My V-10 is randomly missing with NO check engine light or codes. I have 150k mi. I changed out all the plugs and noticed one of the coils makes a high pitch tone when the connector is unplugged or plugged. I also put 2 cans of Sea Foam in a full tank. No change. Any ideas?
Thanks
Old Dec 14, 2013 | 02:35 PM
Stewart_H's Avatar
Stewart_H
Moved to the V10 6.8L forum where the experts can get you dialed in.
Stewart
Old Dec 14, 2013 | 06:42 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I would start by changing the coil boots.
Denny
Old Dec 14, 2013 | 07:48 PM
Manny512's Avatar
Manny512
i just had that happen to me. and my issue was the pcv valve hose was cracked. hope this hepled
Old Dec 14, 2013 | 09:46 PM
pumpcaptain
Thanks for the advice guys. I'll look in to both.
Old Dec 15, 2013 | 06:40 PM
PROSTOCK's Avatar
PROSTOCK
Mine was missing too, no light. Changed the plugs, which it needed anyway, still missed. Then took it to my neighbor who has a Snap-on scanner and was missing on 2 cylinders = bad COP's. He had Advance brings us new COP's and he helped replace them for nothing. (I brought him a 30 pack anyway) After replacement it runs great. I love that guy.
Old Dec 16, 2013 | 05:59 AM
pumpcaptain
The scanner I used was the top of the line Snap-on. Thanks for the response though.
Old Dec 16, 2013 | 07:07 AM
projectSHO89's Avatar
projectSHO89
Driving a Ferrari to the grocery store does not make one a race car driver. Likewise, having one of the best scanners available does little good unless you know how to use it to its best advantage.
You have to go in and look at the Mode $06 Test $53 data directly to identify the misfiring cylinders on non-MIL misfires.
Old Dec 16, 2013 | 06:20 PM
pumpcaptain
How right you are. My friend had the scanner so I'll have him re-try it with that info.
Thanks
Old Dec 16, 2013 | 11:03 PM
Randallman's Avatar
Randallman
^^^ Can someone please decifer the second line into simple English? ^^^
I have a 2000 with 156k miles, plugs were changed at 150k with new boots, PCV valve hose replaced at 146k and the same random hesitation. I have the 5 Star SCT X3 tuner but I'll admit I dont "how to use it to its best advantage."
Old Dec 17, 2013 | 05:44 AM
projectSHO89
Resources:
https://www.google.com/search?q=ford+mode+06+data
urebro
Jan 24, 2018 03:14 PM
jerem0621
Modular V10 (6.8l)
May 5, 2012 10:34 PM
Estam
Feb 9, 2012 11:08 AM
jstanley
Dec 28, 2011 05:55 AM
79schaefer
Modular V10 (6.8l)
Sep 26, 2007 07:21 AM
