My '03 triton is showing code PO171, and the diagnostic reads no voltage from 02 sensor 1, bank 1. I don't know exactly where this sensor is located (I haven't looked yet). I think I would like to swap sensors between bank 1 and bank 2, then run diagnostic again. Is that a reasonable plan?
Not sure exactly what V10 you have but on my 00 V10 excursion they are on the back side of the pipes, this is the drivers side which is fairly easy to reach
Passenger side is a reach, you can see it in this photo only because my pipes are cut off during the header/exhaust project I was doing. You need octopus long arms and an O2 socket, or offset socket.
