Triton v10 funky missfire - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-17-2018, 08:36 PM
urebro urebro is offline
urebro is starting off with a positive reputation.
I've got a 2002 ford f250 superduty that has the 6.8 triton v10 and about 130k miles, and it will run fine when starting in the ten degree weather, but a mile or two down the road will start having a nasty missfire. Has anyone else had this issue?
Old 01-17-2018, 09:21 PM
Boaterguy Boaterguy is offline
Boaterguy is starting off with a positive reputation.
Might be a few things, do you have a check engine light? Faulty coil on plug possibly? Does it have a pronounced miss or hardly running when it happens?
Old 01-17-2018, 09:50 PM
I have no check engine lights, and it is a pronounced miss, it has lost a whole lot of power though.
how would I go about figuring out which cylinder the missfire is in?
Old 01-17-2018, 09:51 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
A misfire on this truck wouldn't set a check engine light unless it was equipped with CA emissions. Scan it for codes and see what shows, I'm willing to be you have a failing coil.
Old 01-17-2018, 09:52 PM
thank you, I will check that tomorow.
Old 01-17-2018, 10:16 PM
Quote:
Why is That? The obd2 should detect a misfire once it happens x amount if times, I have never heard that it's only on carb compliant vehicles.
Old 01-17-2018, 10:33 PM
Tom's Avatar
Quote:
Because the early Super Duties weren't OBD2.
https://www.ford-trucks.com/forums/5...t-come-on.html
Technically OBD1 compliant, which means CEL will not illuminate for a misfire code.
Old 01-17-2018, 10:43 PM
See? You learn something new every day.
Old 01-17-2018, 10:53 PM
Tom's Avatar
Yeah, it threw me for a loop on my old Excursion. I thought it was misfiring, but was perplexed by the lack of a check engine light.
Scanned the PCM and saw misfire codes, and then I read that it wasn't OBD2.
Old 01-18-2018, 07:07 AM
Bugzilla46310's Avatar
Bugzilla46310 Bugzilla46310 is offline
Bugzilla46310 has a very good reputation on FTE.Bugzilla46310 has a very good reputation on FTE.Bugzilla46310 has a very good reputation on FTE.Bugzilla46310 has a very good reputation on FTE.
I vote on the coil. Going to Disney towing a 30' camper, about an hour out I lost a coil. Made it to Georgia ok on 9 and had the work done at a shadey Ford dealer (complained to Ford but they stated they could do nothing). No warning lights ever came on. Had a Ford dealer in Florida redo the bad work (brakes) and that drained most of our vacation cash. It was and still is, a memorable trip.
Old 01-18-2018, 03:06 PM
Copper.Farm's Avatar
Copper.Farm Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
Check the vacuum line for the MAP sensor, they tend to crack.
Old 01-18-2018, 03:28 PM
Quote:
where is the MAP sensor?
Old 01-18-2018, 03:29 PM
update
I've hooked it up to a code reader and it shows no faults, I've also learned that it is burning oil, this isn't a head gasket issue, is it?
there's also a slight smell of antifreeze, but I spilled some on the engine recently, so I'm not sure if that has anything to do with it
Old 01-18-2018, 04:58 PM
Tom's Avatar
Quote:
It's possible, but lots of us have had properly running V10s that go through oil. Mine would burn a quart of oil every 1,000 miles. How fast is it going through oil?
It could have something to do with it. Is the coolant level stable, or is it dropping? It shouldn't consume any coolant.
Old 01-18-2018, 05:23 PM
maticuno's Avatar
maticuno maticuno is offline
maticuno is gaining momentum as a positive member of FTE.
When was the last time the IAC was cleaned/replaced?
Re doing heads on 6.8 v10 2v Mikspi45 Excursion - King of SUVs 5 09-29-2017 11:13 PM
Misfire! Mrdbraun Modular V10 (6.8l) 9 02-08-2017 10:19 PM
2007 Ford F-150 4x4 5.4 triton missfire 07f1504wd 2004 - 2008 F150 1 11-20-2016 10:07 AM
Misfire! Mrdbraun 1968-2013 Full Size Vans 3 05-17-2016 12:19 PM
99 F150 multiple codes Christopher Walker 1997 - 2003 F150 2 03-01-2016 12:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
