please help me choose
Old Dec 13, 2013 | 06:52 PM
  #31
HokieHiVPI's Avatar
HokieHiVPI
Originally Posted by mecdac
You know, we could have done this in one page if we had more information in the initial post.
Help us help you.
Could have done it without the gun posts as well.
(ducks)
Old Dec 13, 2013 | 07:01 PM
  #32
mecdac's Avatar
mecdac
(ducks)
I know, I could not come up with an effective analogy.
My bad.
Old Dec 13, 2013 | 07:07 PM
  #33
mtr727's Avatar
mtr727
Sorry about that, my initial post was kind of rushed. Now I want to upgrade the front end. Is eBay the best place for the grill and light? Does anyone know of a certain vendor to use?
Old Dec 13, 2013 | 07:14 PM
  #34
HokieHiVPI's Avatar
HokieHiVPI
I went with eBay, yeah. I bought http://www.ebay.com/itm/2005-FORD-F-250-F350-GRILLE-GRILL-CONVERSION-1999-2004-/110652517332?pt=Motors_Car_Truck_Parts_Accessories&hash=item19c3676bd4, but it had the billets in it already, and is ready for paint.
I bought Eagle Eye headlights http://www.ebay.com/itm/1999-2004-FORD-F-250-F-350-SUPERDUTY-00-04-EXCURSION-LED-FACELIFT-HEADLIGHTS-/400269463942?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AExcursion&hash=item5d31eb5186&vxp=mtr with the LED in the middle.
I had to hack the shirt out of the header panel to make them fit, but they look great now and I'm very happy with them!
Old Dec 13, 2013 | 07:42 PM
  #35
mecdac's Avatar
mecdac
I went a different route:
The Grill-
Ford Paintable 05-07 Super Duty/Excursion Grille Fits 99-04
The Lights w/HID and DRL-
HID Xenon + 99-04 Ford F250 F350 Superduty LED Crystal Headlights - Black
Or you can find an F250 grill in a salvage yard, lots of options.
Old Dec 13, 2013 | 09:58 PM
  #36
WE3ZS's Avatar
WE3ZS
Originally Posted by mtr727
I choose the v10. It has brand new 305/70/16 on it. It's much cleaner than the 7.3 and I got it for 6k less than the 7.3. What kind of sway bar is recommended? Also how much to re gear?
Congrats on the purchase, now we will all be more than happy to help you spend your money!
Your 305/70R16 tires look to be 33" tall as opposed to the stockers at 31.5". So if you are going to regear for better towing I would go with 4.56 gears to keep the effective ratio at 4.30 or above. What gear ratio does your EX have to start with? Is your EX a 4X4? If so both axles will need to be redone with new gears, about $2k total depending on your location and the shop chosen.
The Hellwig rear (anti) sway bar is a great addition to our trucks, and the new design of Hellwig's end links allows for some adjustability, nice improvement over the older style I used.
As for towing your 7k camper, make sure those tires are load range E, and invest in a good (or better than good) weight distribution hitch with sway control. The factory springs on our EXs can be a weak link while towing heavy, you may be OK at the weight you plan to pull, or not......... A good test run with your camper loaded up will let you know. Respringing to a good set of F-250/350 springs is fairly easy and can be done by almost anyone with a helper, they are heavy. Lots of info here on spring swaps, that's a pretty common mod for EXs. My upgraded springs made my Ex into a new truck! I pulled a 31' 9.5k lb ToyHauler with mine for 3 years and over 20k miles, it was unpleasant to say the least with the stock suspension. With the new heavier springs it is a joy to drive and all of the past handling issues are history.
Tyler F
Dec 7, 2018 09:05 PM
59CRL
Mar 17, 2013 12:50 PM
screwy
Jan 27, 2013 10:09 AM
Spencon
Feb 7, 2011 12:17 AM
Want_a_7.3diesel
Oct 7, 2009 09:17 PM
