2" leveling kit
Old Dec 12, 2013 | 06:24 PM
beemr's Avatar
beemr
2" leveling kit
Has anyone had experience with the 2" leveling kit from Summit Engineering? It looks like a 2" aluminum hockey puck that installs under the spring on top of the front axle.
I have a 2005 CC LB 6.0 that I am wanting to level out.
Old Dec 12, 2013 | 07:24 PM
raptor131's Avatar
raptor131
Do you have a link? I went with ready lift. You may need new shocks for the front to add length of travel. The kit I used is steel and has rubber bushing and mounts on top of spring. But same principle
Old Dec 12, 2013 | 08:18 PM
jswartz84's Avatar
jswartz84
I used the same Ready Lift as Raptor. Works great and it also came with shock extenders.
Old Dec 13, 2013 | 06:52 AM
raptor131's Avatar
raptor131
They must have come out with those after I bought mine. I had to buy longer front shocks! Lol
Old Dec 13, 2013 | 10:23 AM
Carolina Rig's Avatar
Carolina Rig
I am not familiar with these, but I installed the Zone Offroad 1" leveling "pucks".
Whether you go with 1" or 2", they install fairly easily and should do fine for you.
The 1" is all my truck needed and gives it the stance I prefer.
However I think I hear of more people purchasing the 2" spacers that you happen to be looking at.
Old Dec 13, 2013 | 12:36 PM
snorindad's Avatar
snorindad
I use the carli leveling kit that comes with bilstein 5100, longer springs, adjustabel trac bar, brake line estensions and cam shims.
Leveling Kit for 2005-2012 Ford Super Duty F250/F350 4x4 trucks
Old Dec 13, 2013 | 03:22 PM
Yahiko's Avatar
Yahiko
Look at you truck on level ground.
Some 2" kits can give the back end of the truck
a tail down look.
To fix that you have to change the rear blocks and make sure
that you get the right type. I now have a set of 5" tapered blocks
I can't use with my truck.
Sean
Old Dec 13, 2013 | 04:29 PM
snorindad's Avatar
snorindad
a tail down look.
Sean
If I remember correctly or at least with the kit I bought if you have a F-250 you change the rear blocks and on a F-350 you do not have to. Do not remember where I read or someone told me but that is what I remember.
iexcur
May 19, 2016 06:36 PM
blazr190
Mar 31, 2013 04:38 PM
jda1961
2009 - 2014 F150
Jun 5, 2009 07:27 AM
gui88ford
2004 - 2008 F150
20
Feb 13, 2009 07:35 PM
SDTruckMan
2004 - 2008 F150
Aug 24, 2007 07:58 PM
