Sponsored by: Auxito
2 problems
Old Dec 12, 2013 | 04:13 PM
jmcnulty's Avatar
jmcnulty
2 problems
hey guys I have an 02 f150 ext cab fx4 with just under 140,000 miles my first problem was when I shift from reverse to drive I have a loud clunk/bang I was trying to find out what was wrong so my brother in law was looking out the drive shaft he pushed it into the rear end now when I am over 65mph and take my foot off the gas I have a vibration but only when I take my foot off the gas and above 60-65mph the steering wheel or peddles don't vibrate but the floor does thanks in advance
Old Dec 12, 2013 | 10:09 PM
Lime1GT's Avatar
Lime1GT
Could you correct spelling or explain what you mean
Old Dec 13, 2013 | 09:09 AM
steve(ill)'s Avatar
steve(ill)
when he pushed the drive shaft backward, it should not go "into" the rear end. If the pinion shaft moves back and forth in the axle, that is BAD. If he moved the drive shaft and it is sticking on the splines or similar, then you need to remove, clean and grease it.
Old Dec 14, 2013 | 08:31 PM
jmcnulty's Avatar
jmcnulty
I will be back under the truck tomorrow looking to see exactly what moves
phazer
1997 - 2003 F150
Jan 25, 2007 08:44 PM
mdf250
1997 - 2003 F150
Sep 2, 2006 03:22 PM
wyldbillracer
Sep 20, 2003 10:25 PM
longview1
Jul 12, 2003 07:39 PM
