Drive line ?
Old Sep 19, 2003 | 06:34 PM
wyldbillracer's Avatar
wyldbillracer
Drive line ?
When taking off from a stop it feels like something is loose or has slack, feels like it may be with the drive shaft, with the truck on the lift everything seems to be secure any ides? Thanks
Old Sep 20, 2003 | 10:25 PM
philn's Avatar
philn
Drive line ?
My '02 F-250 has the same relative problem. I greased the splines on the rear drive shaft and it helped a bit, but didn't correct the problem altogether. I can rock the truck back and forth while looking under it and see the the pinion popping up and down. Might be the bearing. You may also need to look at the carrier bushing to see if it's worn out. From reading most of the posts it's usually the splines needing grease. I'd try that first. You will have to remove the rear U-Joint and let the drive shaft down in order to pull the shaft apart. Once apart, you can grease the splines. When you slide the splined shaft back together it only goes one way. You can do a search for "splines" and get very thorough instructions for this. Good luck!
